Is there a common Vacuum leak pipe
I'm not too familiar with this problem but to start off, of course take off the plastic cover.
If you haven't done this-careful- because the plastic clips are very brittle. Take your time.
Run your car outside, Not in the garage as it will be too loud to hear any hissing.
Listen for it and look around of course for any loose or unconnected fittings. Even broken fittings.
If all look ok, quickly turn off the engine and listen for any negative pressure hissing anywhere.
If all appears good, use a mild soap solution and squirt it around all hose joints. Of course if there's a leak it will bubble. Thats with the car on.
Also watch out for leaks along the hose just not only the fittings.
Is it original? Ever been cleaned?
How does the car start and idle?
Cheers.
