Catalytic converter rattling, no more remans available?
Then after some quick googling I found a magna flow replacement which is said to fit the E55 and is CA / CARB compliant http://www.magnaflow.com/products?partNumber=444105 . Will this work? Should I verify that the catalytic concerts are really out of stock?
Any insight / info / advice is appreciated.
Thanks,
From my understanding that's just removing the secondary pipes? is there any downside or issues with going this route?
thanks again for the reply
2.5" Magnaflow Universal 59956 High Flow Spun Metallic Catalytic Converter
This is what I'll get if my primaries go. This one is 200 hi flow. I had deleted my secondaries a few years ago and had x-pipe in place. I haven't had any issues with this set up and the sound is better. Seriously, these cars never really sound loud unless you had the muffler delete but for normal daily driving, it only growl when you step on the gas
I'm still not convinced on the 2ndary mod. The sound is great tho.. Maybe when the 2ndary cats fail I'll be more inclined to make that mod.
Thanks again,
Thanks again for the responses
I am going to go ahead and replace my primaries with high flows upon delete and x. My question is what is the size of the oem primaries? Do these need to be modified to fit? Can I get any cat as long at they are metal and the same size as these?
