Steering wheel replacement.
Old Aug 15, 2016 | 08:51 PM
RPB's Avatar
RPB
Hey Guys,
The time has come to replace my stock steering wheel which is worn. I found a compatible replacement, i would like to obtain insight with regard to the replacing it with the new one. The UTube videos can be deceiving at times. The center bolt looks to be very tight which is something i would anticipate.
Any info you could offer up would be appreciated!!
Cheers,
-Rob
Old Aug 16, 2016 | 08:09 PM
RPB's Avatar
RPB
Originally Posted by Plutoe
When you say compatible, you did so by using EPC correct, or was this the girlfriend saying-wow that i'll work!!
Lol.. I had someone at the local dealership confirm it will work.
Thanks.
Old Aug 16, 2016 | 10:24 PM
suicidal4life's Avatar
2001 E430
It's been several years since I swapped my steering wheel. I do not recall it being difficult at all. There is a DIY posted here or on benzworld somewhere that lays it all out.
Old Aug 17, 2016 | 07:24 PM
noud's Avatar
99 E55, 00 S500, 01 CLK55, 01 E320, 04 E320
It is straight forward.
Center bolt is headache. Use powerful torque gun or use long pipe as a lever. Ask someone strong to hold steering wheel while you'r trying to break loose center bolt, dont use steering wheel lock as a counter force.
PS. make sure your steering wheel and wheels are straight aligned
