What to do when you go to install headers and the first 2 bolts snap in the head.
Damn!
Originally Posted by turbo1k
(Post 6972500)
Pull the motor
https://cimg9.ibsrv.net/gimg/www.mbw...ad94c32881.jpg
I guess it will be easier to fix the valve cover gaskets with the motor out |
Originally Posted by Tall Giraffe
(Post 6972590)
How did that happen? could not break the bolts cleanly?
On another note not what are these motors and transmission worth. Now might be a good time for a turbo LS swap. |
She is all unbolted just need to pull her out.
https://cimg8.ibsrv.net/gimg/www.mbw...3d8b72f21f.jpg |
It's out and the broken studs are removed. One more broke on me so there was a total of 3. The broken studs came out very hard and with lots of heat. There is no way this could have been done in car.
Now I have a few questions. Whats the Tq spec on the valve cover bolts,oil pan(upper and lower), rear main seal plate and intake manifold bolts? Also I removed the EGR tube from the manifold, how does this go back together? https://cimg9.ibsrv.net/gimg/www.mbw...a9244c7e13.jpg https://cimg0.ibsrv.net/gimg/www.mbw...577ae31b1d.jpg https://cimg1.ibsrv.net/gimg/www.mbw...462d85667c.jpg |
Good on you, what a nightmare! Do your rear main seal while it's out, I've got to do mine and I'm dreading pulling the trans to access it. How long did it take to get the engine out start to finish?
Originally Posted by IanB
(Post 6974999)
Im also doing the rear main seal, valve cover gaskets, and re sealing the oil pan. Steve |
Sweet mother of everything that is holy and pure! I was thinking about changing out my headers and now I am scared crapless.
me too.
Originally Posted by rnelson
(Post 6976550)
(Post 6976550)
Guys these cars are getting old and old cars have a lot more problems than they did when new. Mercedes or not 16 years old and 240k miles corrosion and rust become major problems. In the last 2 years I've had every suspension,drivetrain, and break part out of this car. If you take your time and have some mechanical skill you can do it. These cars are pretty basic and are a great deal these days. If your not sure about something just ask or do research on it first. Steve |
Not much progress today. Just removed the rear main seal and cover. Cleaned and installed the valve covers.
https://cimg2.ibsrv.net/gimg/www.mbw...41de5beab6.jpg |
Resealed the upper and lower oil pans. Installed a new rear main seal. New exhaust manifold studs,nuts, and gaskets. Just about ready to go back in, hoping for tonight if I can get away.
https://cimg9.ibsrv.net/gimg/www.mbw...fc8d9a023c.jpg https://cimg0.ibsrv.net/gimg/www.mbw...8271f93e91.jpg https://cimg1.ibsrv.net/gimg/www.mbw...e3fb60f1e8.jpg https://cimg2.ibsrv.net/gimg/www.mbw...27d057d15b.jpg https://cimg3.ibsrv.net/gimg/www.mbw...f4f879fedd.jpg https://cimg4.ibsrv.net/gimg/www.mbw...b5b2efb433.jpg https://cimg5.ibsrv.net/gimg/www.mbw...0efe76c45c.jpg |
Wife said we weren't leaving until noon so I figured why not put the motor in.
https://cimg7.ibsrv.net/gimg/www.mbw...f174e02f78.jpg |
Nice work!
Good stuff! I'm really glad you took lots of pics, I don't think I've seen another thread where anyone pulled the engine on one of these cars.
:bow:
I was able to spend a few more hrs on her tonight. New water pump and thermostat.
https://cimg4.ibsrv.net/gimg/www.mbw...1416de4c96.jpg |
Intake is on and all wired up. I also split the intake and clean it up. Sorry no pics of that step. It was by far the worst part of the job. The egr tube was a little difficult and I broke the nipple off the solenoid on the front 😡 Going to attempt to fix that tomorrow. Just the O2 sensors, and everything in front of the motor. Putting a new condenser and fan shroud in.
https://cimg4.ibsrv.net/gimg/www.mbw...15a6e6accc.jpg https://cimg9.ibsrv.net/gimg/www.mbw...d4fcc5d52e.jpg |
when you split the intake manifold, did you also replace the thin rubber air hose which is connected to EGR valve in front of the intake manifold?
rubber hose is on the under side in front of intake manifold. when rubber hose goes brittle from engine heat it's a cheap part to buy, but you have to buy complete intake manifold fitted with rubber hose if you want to replace this brittle hose, and that's because of a design flaw from Mercedes engine team. intake manifolds are only sold complete with rubber hose at stealership. cheapest way to repair is to split intake like you did and do a MacGyver repair |
The rubber hose was still in good shape and functioned fine. One thing I did do is put a bunch of silicone around the hose where it entered the manifold just to help protect it.
Got the new ac condenser in. Just waiting on some parts from Mercedes to finish this thing up. https://cimg1.ibsrv.net/gimg/www.mbw...1cfd203813.jpg |
good god youve obviously done this before. i am a wiz at carbs and brakes but id never attempt to pull a motor!
Originally Posted by MNR
(Post 6979280)
I'm showing my age lol Steve |
what header are you using ?
