E55 AMG intake on E430
Old May 4, 2017 | 11:50 AM
autopressagency's Avatar
W210 E430 Avantgarde
Hello
I am going to do this mode to my car, and any advice is reasonable for me. So i have a chance to buy whole W210 E55 amg intake system at very good price, so i am thinking will it fit on my E430?
I mean that, I think that the cover will directly fit on my 430, they are same looking M113 engines.
I know that this mode requires some MAF relocate, on E55 Maf is installed on the back of the engine, close to the trottle body. So are there any issues connected MAF relocating?
also wanna know what additional parts will i need for this mode? (does e55 has any different hoses which connect maf and trottle body?)
and will this mode give me some performance + ?
for the clarify wanna transform this:
to this:
Thank you
Old May 4, 2017 | 03:19 PM
cm60k's Avatar
Need to change the following items:-
"E55 Radiator with upper hose/Radiator shroud/fan shroud/left side air scoop/MAF elbow"
-;ZAYED;-
Old May 4, 2017 | 04:37 PM
kaype's Avatar
W109 300SEL6.3, W123 280TE, W123 200T, W210 E55
Also you´ll need the waterdrain in the hood otherwise you cant close the hood ;-)
Old May 5, 2017 | 03:35 AM
So, as i see needs more effort than i thought
That's why i'd better leave the stock.
Thanks for help
Old May 5, 2017 | 05:44 AM
cm60k's Avatar
Good catch Fabian, beat me on this..
-;ZAYED;-
Old May 5, 2017 | 08:11 AM
kaype's Avatar
and i forgot: You need the vacuum line to the Brakebooster and the fuelline including a longer fuelline to the fuelpump in the rear otherwise you cant fit the AMG Filter on the left bank because the non-AMG Fuel Line and Vacuum line are in your way.
Old May 5, 2017 | 08:43 AM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
I have an E55 intake manifold, that will gain power over stock also. For sale.
Old May 5, 2017 | 11:32 AM
kaype's Avatar
E55 and E430 intake Manifold are 100% the same ... its #A1131400701 on all M113 N/A Engine, no matter if 4.3, 5.0 or 5.5 Litre.
greetings, Fabian
Old May 5, 2017 | 12:14 PM
cm60k's Avatar
^^..+1 with this prof. master, follow him with anything he said..^^,,
great helpFUL, nooooooooooo doubt..
-;ZAYED;-
Old May 5, 2017 | 06:24 PM
benzslo's Avatar
Sorry, but you guys are wrong. I don't care what the EPC of today says, that only means the parts you're going to get today. Not what your car was equipped with when new. It's called supercession.
I have a large box of all c43 info from 1998, both MB provided and rare, and some consumer magazines like car and driver. I'll post pictures in the next post. Only doing this because it's been disputed in other posts and I let it go but it's annoying. This is why knowledgeable MB guys don't bother with forums. For now see these links I just googled.
And PS both my manifolds have AMG stamping all over them. And both the c43 and E55 were even different from eachother both in manufacturer number and performance.
https://books.google.com/books?id=YG...nifold&f=false
https://www.google.com/amp/s/www.top...07175.amp.html
Old May 5, 2017 | 06:46 PM
benzslo's Avatar
Pictures of real information.
Attached Thumbnails E55 AMG intake on E430-img_20170505_172752185.jpg   E55 AMG intake on E430-img_20170505_173204978.jpg   E55 AMG intake on E430-img_20170505_173703843.jpg   E55 AMG intake on E430-img_20170505_173838482.jpg   E55 AMG intake on E430-img_20170505_173321724.jpg
Old May 5, 2017 | 07:08 PM
cm60k's Avatar
Good to know about those sources bro.,
i had "3" C43's, "2" 98 & "1" 99, i opened the intakes and compared them with 5.0l & 5.4l intakes last year,
i can assure to you, no any difference between them..!?!,,
i bought 06 Slk55 intake "4" months ago, also, no difference..!!-!!
maybe AMG modified their own C43 intake for track or drag reason..?!?!?!
-;ZAYED;-
Old May 5, 2017 | 09:05 PM
kaype's Avatar
My ´00 E430 also had the "AMG" stamp on the intake manifold... so?
Sorry bro ... all M113 N/A have the same intake manifold... i also checked my epc database from days ago ... also says the same, my latest database is from 2004.
greetings, fabian
Old May 6, 2017 | 11:04 AM
6spd's Avatar
00 ML55, 00' E55, 03' CLK55
To the OP, you are better off running piping from the MAF down into the bumper where you can put a cone filter. Gains maybe negligible on a 430 but the sounds will be great!
I have a 430 intake tube on my 55. It's great flowing as the arm is pretty big in diameter. The box is the part that you'd want to change, either to the clk320 box or an open element cone style filter re-located in the bumper.
Old May 6, 2017 | 12:28 PM
benzslo's Avatar
Sorry but I'll take info straight from Mercedes-Benz over forum jockeys. 8 days a week.
Old May 6, 2017 | 12:38 PM
cm60k's Avatar
As you like bro.,
but pls. if you find any difference, let us know, it will definitely be useFUL.
-;ZAYED;-
Old May 6, 2017 | 12:54 PM
kaype's Avatar
You are free to take your info from where you like, no problem with that. but if you take your info from mercedes directly they will tell you nothing different then i am telling you:
Original Mercedes EPC Screenshot:
Intakemanifold A1131400701 used in all N/A M113 including your C43 with Engine M113.944
And as i told you, my Modelyear 2000 W210 E430 had an AMG Sticker on the intake manifold. Maybe AMG changed something on the really early M113 intake manifolds as Mercedes bought AMG 1999 and the M113 was introduced in 1997 but then the "normal" non-AMG M113 Cars where also equiped with this intake manifold. no benefit or whatsoever in changing the intake manifold. If you want believe it or not ... i dont care :-)
Actually i have an opened intake manifold of an 2000 ML55 in my workshop for cleaning, when i am done i make some pictures and check the partnumber.
greetings, Fabian
Old May 6, 2017 | 01:37 PM
6spd
I know that Clk320 air box has 2 snorkel, just like the C36 amg air box, but i think that these air boxes will not fit on W210 or i am wrong? (is it possible to fit them on W210 without heavy modifying)?
about open element cone filter i am a little sceptical, (I already had Gruppe M carbon intake with K&N). I prefer factory look
__________________________________________________ ________________________
About intake manifolds i wanna say that when i check this part number via EPC A1131400701 it shows to me that every NA M113 has this part too. But i also found this part number on net: A113 140 05 01 and my EPC doesn't recognizes this part nubmer. Here is image where it is written on the manifold:
Old May 6, 2017 | 03:50 PM
6spd's Avatar
I've never tried the clk box, but I do know you can fit the coolant reservoir sideways. And then maybe it would fit. I have a standard 430 airbox for when I have to pass smog. Biggest difference I notice is that with the open air filter top end power is greater with more turbulence from the induction, but with less low end response. With factory airbox low end is greater with very smooth quiet airflow, while top end is slightly reduced.
I've also noticed the computer adapts to both stock airbox aftermarket in different ways.
[Q2UOTE=autopressagency;7138896]6spd
[/QUOTE]
Old May 6, 2017 | 04:22 PM
6spd
I saw your setup here, and it's quite impressive
For me as i already said i prefer stock look, and that's why i see no big + to move coolant reservoir, also i checked and W210 has different air box mounting diagram than W208. I agree that Stock system flows more smoothly and i like that method.
So i'd better leave the stock. Now i am running it with AFE Power MagnumFLOW Pro Dry S Air Filter. Soon gonna change it to BMC.
Old Oct 18, 2023 | 08:56 PM
Gutentight11's Avatar
E430
Originally Posted by cm60k
As you like bro.,
-;ZAYED;-
i think the stock e430 single air intake system flows the same if not better than the dual amg style , correct me if i am wrong
Old Oct 19, 2023 | 10:25 AM
cm60k's Avatar
Really not worth it, as you will need to change many parts!!,,
depends on your desire ..
(-;ZAYED;-)
Old Oct 30, 2023 | 09:47 PM
E430
what the W210 is missing is a bigger hole underneath the airbox like you see in this picture it needs to be cut and made bigger so a 3 1/2 inch to 4 inch pipe can be fed down to the fog light area. THEN , u can add a real CAI and actually gain some power!
