how to check if the k40 is fine
Old Aug 7, 2017 | 03:22 PM
kerneur974's Avatar
w210 e55
hi everybody ! i still have a esp ecu problem and someone suggest me to checking if the k40 relay have no trouble and if he deliver 12v to the esp ECU...if someone know how to do it.
i would like also to know how to remove the ecu safely.
thank you !
oliver.
Old Aug 7, 2017 | 04:31 PM
PJmak's Avatar
What exactly is the issue with esp/ecu?
Old Aug 8, 2017 | 02:12 AM
kerneur974's Avatar
w210 e55
my car have power issues and lights of (abs esp bas) sometimes here and sometimes not, also my steering wheel is sometimes strong and sometimes not , the car running slugglish most of the time but suddently it can be a beast...
i Went to the mercedes dealer and they telling me its the esp ecu unit to change and that all those problem are related to this...
Put the mercedes diag i have those codes coming of the ESP ecu unit on
(C1149,B24/2,B34,A7/7B1) The voltage supply of the components has interrupt or short circuit
(mass air flow sensor already change still power issue)
cant it be a k40 voltage problem ? i suppose i have to check the voltage of the relay before changing my esp ecu
Old Aug 28, 2017 | 04:05 PM
kjarboe's Avatar
2004 CLK55 AMG, 1987 BMW M6, 2000 Lexus Lx470, 2003 CLK500(SOLD), 2000BMW540i(SOLD), 2005 350Z(SOLD)
I had terrible experiences with my MB dealer in regards to them diagnosing issues. I used to have a CLK500 that got some pretty major water damage from a clogged drain vent. ECU, SAM, and bunch of other stuff they said it was all bad quoted me $5800. Friend of mine recommended an indie specifically good with Benz and he went through and tested everything and found only the ECU to be bad. $1000. My point is if you feel you need to bring it to a shop do not bring it to the dealer they just throw parts at cars. You may have much better luck with an Indie.
Good luck!!!!!
