Replacement radiator help
Old Nov 29, 2022 | 03:29 PM
Bill Cardoza's Avatar
2000 E55 AMG
Replacement radiator help - 2000 E55 AMG
The plastic end of my radiator my 2000 E55 AMG has a huge crack. I’m assuming that it can’t be repaired so I need a recommendation for a brand of radiator and what to be aware of when I replace it. Things like seals etc.
Thanks in advance
Last edited by Bill Cardoza; Dec 1, 2022 at 07:32 AM. Reason: Adding vehicle make and model
Old Dec 26, 2022 | 04:53 PM
turbo1k's Avatar
2001 E55 1999 E55 2001 ML55 2017 C43
Yes you need to replace it I’ve used Behr in the past. Pretty straight forward nothing special. Good time check your coolant, fan clutch, water pump, pulleys, belt and any oil leaks from the front of the motor since it will be easy to access with the radiator and fan shroud out of the way.
steve
Old Dec 27, 2022 | 02:16 PM
MattCordell's Avatar
C43 AMG with a tune up
Aftermarket Behr is made in China, you don't want this part.
Buy MB original even if it costs a lot more.
Old Dec 27, 2022 | 05:41 PM
PJmak's Avatar
Behr is fine. What kind of connections do the transmission lines use on the 210? If it uses the metal clip retainers like in the 209s and 203s, you'll want to use your old factory ones as they are made of harder steel.
I had issues with lines popping out when using the retainers that came with the radiator.
