Evosport Intercooler Upgrade.
Old May 15, 2006 | 11:40 AM
BIG LUV's Avatar
'06 E55 Black/Charcoal
Is it overkill or is it worth the extra money? Is it just as effective to buy a larger pump?
Old May 15, 2006 | 11:44 AM
jangy's Avatar
2015 S212
I have not done it, yet. It is an upgrade from what I can tell. Do you just want it, or are you having temp issues?
Old May 15, 2006 | 11:52 AM
BIG LUV's Avatar
Forced Induction cars always run better cooler. I was just wondering about it since I was planning to modify my car. Heat soak is a killer. I just wondered if it was overkill, considering I see most guys in here ar just upgrading their pumps.
Old May 15, 2006 | 12:06 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I stuck my head under my bonnet over the weekend and had a quick look see whats what with the intercooler setup.
At first glance the existing heat exchanger looks fairly substantial in size. I think the I/C unit under the blower is whats rubbish, and I reckon a higher flow pump will help allot.
Also about bleeding the system - I noticed a valve cap (similar to valve stem on wheels) on one of the pipes leading to the IC unit. Surely using this valve must be easy to bleed the system ?
Using the radiator engine coolant volume I think also helps - I am not sure splitting the system is that great an idea.... try a faster pump and check your IATS - but you need to do it in same conditions - otherwise data will be meaningless...
Old May 16, 2006 | 12:22 AM
Vadim @ FD's Avatar
S600TT, R350
Do a search under "intercooler" on this forum and you will find quiet a bit of information going back several years.
Old May 16, 2006 | 12:37 AM
MB Fanatic's Avatar
4 wheels
I just upgraded the pump and then had the Star Diagnostics mod where the fan and pump are engaged 10 celsius lower than stock settings. So far its helped and you can hear the fan in the E55 kick in much more than when it did stock.
Old May 16, 2006 | 10:52 AM
BIG LUV's Avatar
Where can I get a new Pump?
