Low beam bulb replacement DIY??
As for room you should have enough to pop off the black cap and access the bulb housing??
Thanks Vic- My manual also 'recommends' that I take it in but honestly, I would feel like an absolute schmuck if I had to go to the dealer to get a bulb replaced! there's actually zero clearance so I think there should be a process of taking a few bolts off to pull the light housing out. I just dont want to tear into it just to find out there was a REALLY simple way!
A brief rundown. First remove the black cap off the back of the headlight. It just snaps off.
The bulb and the igniter are attach together so you will have to remove them both. It is in three parts igniter, bulb and a outer ring. The outer ring attachs the bulb and igniter to the housing. Twist off the ring. Should be counter clock wise. Again be very careful with the bulb. Not to much space to work with.
Once out remove the bulb. If I remember it just sits in place. Thats the part I forgot but it will be self explanatory once you see it.
If very thing was done properly it should be one piece before you reinsert it into the housing.
I know I wasn't too clear but I will be doing it again once the weather gets better. Hope it helps
His should be even easier sans the ignitor (he has halogens). Thanks for the input.
how do i remove the outer ring? is outer ring the metal piece that was attached to the igniter???
