Oil Questions
Old Apr 7, 2007 | 03:27 AM
LazyE55's Avatar
E55
Oil Questions
Searched around but didn't find anything. I am looking to put 10W-60 Liqui Moly oil..the shop i go to recommends them highly. What do you guys think....I know the factory recomends 5W-40. Any opinions?
Old Apr 7, 2007 | 04:00 AM
jdj27x's Avatar
**** U and **** ur shop...
Just playing, whats up bro, did they fix ur problem with the hose?
-Jordan
Old Apr 7, 2007 | 04:30 AM
LazyE55's Avatar
E55
-Jordan
Yeup the hose is fixed and the car is back to running strong
Roy
Old Apr 7, 2007 | 04:38 AM
luderule's Avatar
The white one
Your car still sitting at Lucent?
Old Apr 7, 2007 | 04:51 AM
LazyE55's Avatar
E55
Nope cars been out of lucents for awhile now...running strong
Old Apr 7, 2007 | 05:15 PM
LazyE55's Avatar
E55
Nobody?
Old Apr 8, 2007 | 12:06 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
I guess I chalk this up on how paranoid someone is about warranty more than anything else.
I like running Mobil 1 15W50 in the warmer temps in Chicagoland. I'm convinced it works better overall for the car than the 40 (maybe I lose 10 HP). I also run my oil levels slightly high (whether 40 or 50). The 50 stays clean for a long time, so I'm not worried about any "tight clearance requires thing oil" nonsense.
If I were in Cali/warmer states and was faced with warm temps? Yes, I would consider a 60 weight. I'd go 70 if someone was a trail blazer on this before me.
Old Apr 8, 2007 | 02:30 PM
OzE55's Avatar
2003 E55
I suggest you use what MB/AMG recommend........they did design and build the engine, so they should know what's best.
Old Apr 9, 2007 | 04:33 PM
phatmitzu's Avatar
2005 E55
off topic,
LazyE55, got a picture of your ride?
Old Apr 9, 2007 | 05:24 PM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
They can and will void your warranty using unapproved oil. You don't have to use Mobil 1, but you do have to use what's approved. It's not being paranoid, they have done it to others.
Old Apr 9, 2007 | 05:53 PM
tigerlam92's Avatar
E55
If I remember correctly, MBz recommends 0W-40 for the E55. 5W-40 should be fine.
I would not go to 10W-60 that is just way too thick. Our car is built with certain clearance that may not work as well with such thick oil. Unless your car is totally modded I would follow recommended oil weight. I do not see any reason for you to use this oil.
