help with seat adjustment
Does anyone know how to set the easy access for the driver side to turn on. I had my service done and they reset my seating, when I tried to reset it I can only get the steering wheel to move up instead of both the seat and steering wheel to slide back when i get out. It says in the manual that you can have both how to I set it up. thanks guys
2015 S212
If the wheel is moving up, then the feature is turned on. You likely got a flash. the reason I say that is MB changed the position that the seat must be in for it to go back on exit. If you are already back farther than that point, then only the wheel moves up. This was done to avoid crushing things left behind the driver's seat.
You can turn the feature on and off in the dashboard services menu. You can have the position where the seat moves or doesn't "calibrated" by STAR.
