2 Time Slips - What's the difference
Old Jun 18, 2007 | 11:30 AM
JAYCL600's Avatar
new balance
aahhh ok now i understand the good times....toyo ra1's have the same tread compound as the nitto drag radials nice tire
Old Jun 18, 2007 | 12:23 PM
blackbenzz's Avatar
haters crazy
Originally Posted by SleeperX
275/35/18 in the rear
Nice choice! I run the same tire setup in the rear at the track. I used to run on them everyday but I have 19's for "show" now
Nice runs too!
Old Jun 18, 2007 | 02:46 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
i've run the same 60ft times on true street 19" toyo t1r's so d/r's or r compounds are not needed unless you want into the 1.6's.
Old Jun 18, 2007 | 02:51 PM
blackbenzz's Avatar
haters crazy
Yea but RA1's are more consistent and easier to run better 60's
Old Jun 18, 2007 | 03:02 PM
chiromikey's Avatar
obviously that should be true but i think it has more to do with launch technique and track prep. with fair to decent prep i cut mid 1.7's to low 1.8's all day long...with good prep 1.71's.
as soon as summer's over i'll get to practice with d/r's and see what happens.
Old Jun 19, 2007 | 08:03 AM
E55 RUSS's Avatar
E55K
Thanks for you answers man
So even you have 275/35 on18 on the rear which is bigger diameter then 275/30 19 you still have those amazing times...
I was afraid that my 1/4 times would be worse with 285/30 vs 275/30...
So what is the Enzoms launching technique ??? No pre-load just WOT...
Old Jun 19, 2007 | 08:06 AM
  #32
SleeperX's Avatar
E55
Yep.. Foot on the brake (barefoot I believe). Light turns green, take you foot off the brake, place it on the gas pedal and go..
Old Jun 19, 2007 | 09:21 AM
  #33
E55 RUSS's Avatar
E55K
Hmmm...when I do I have more ESP engagement...
I will try that thanks
Old Jun 19, 2007 | 09:40 AM
  #34
blackbenzz's Avatar
haters crazy
Turn ESP off
Old Jun 19, 2007 | 09:53 AM
  #35
E55 RUSS's Avatar
E55K
Turn ESP off
That this happens
http://www.youtube.com/watch?v=IRlb8vx78wM
Old Jun 19, 2007 | 12:28 PM
  #36
juicee63's Avatar
2011 twin turboed prius
dyno mode man...the car is limited even with esp off!
You need to learn not to smash throttle, the car will give you plenty wait for traction then hammer. Heat the tire for 15-20 seconds prior to your run. Your car should do 11.7
