Running E63 (1/4 mile) without filter housing?
Old Sep 24, 2007 | 12:08 AM
buckeyewalt's Avatar
E63,,,not any more,,,BMW X5 50i
Has anyone tried running the quarter without the filter housing? I mean the entire housing, running straight to the TB? Looking at my engine, I can't help but imagine the restriction that goes on there! You have two big intakes, one from each bank going into a single TB. Question, would the breathing be improved by eliminating filters and tubing entirely? Maybe it has been tried and didn't work out. Just a wild thought on my part....someone in the know probably more than me will have the answere!!
Old Sep 24, 2007 | 12:43 AM
Jrocket's Avatar
E55
Those 2 large boxes have the MAF's in there as well so its not going to be that easy.Unless you just remove the filter element only,which isnt going to gain anything noticable,if at all.
Old Sep 24, 2007 | 01:02 PM
Yep....you're right...looking at the engine...I see the connections. So much for that thought....thanks for setting me straight Jrocket!!
Old Sep 24, 2007 | 03:02 PM
05VENOM's Avatar
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
Are you sure they are MAF sensors and not intake temperature sensors?
Old Sep 24, 2007 | 03:05 PM
Jrocket's Avatar
E55
99% sure.
Old Sep 25, 2007 | 12:34 AM
E63PWR's Avatar
'05 C55
There are dual blade type mass air flow sensors on your E63. I dynoed mine before and then removed both the air filters and charcoal filters and dynoed again. I gained nothing to the wheels. The factory air inlet is designed very well. There may be some more power in the intake manifold area but have not explored that yet.
Old Sep 25, 2007 | 12:58 AM
Thanks for the info I was looking for......I didn't know if there was any hp gains on the restriction where the two air tubes go into one...in the back of the engine...I still can't help but think that with our N/A engines,,breathing is what its all about!!!
Thanks for your input!
