How about a little Light
Old Oct 22, 2007 | 10:20 PM
aganzon's Avatar
W211 E55 AMG
I can confirm that there are error messages
Originally Posted by NGS_E55
James: Please confirm no error messages on W211 after fog installs.
NGS_E55: I bought two of these (9006 type) kits from James. One for the Acura and the other for my E55. The kits were plug and play on the Acura and worked perfectly. No flicker...very clean and bright. I installed the first kit on the Acura first to get "practice." The install is really very simple and only required four connectors. The whole install took me an hour max only because I wanted to do it correctly with all of the wiring harness tucked, tie-wrapped and out of the way of moving parts and electrical interferences such as ABS systems.
Once I got the practice from the Acura and confirming my correct installation, I proceeded to install the second kit on the E55. Again, the install was very simple and required no cutting or splicing. But with the E55's smarts (or call it dumbness) in checking for a burned out light bulb condition coupled with the reduced wattage requirements of the HID kit, the E55 cuts the power from the fog lights.
Their site quotes: "Fully digital, draws less than 6 amps at startup and contains circuitry to prevent modern cars from setting a bulb-out warning message so you can be assured of full compatibility with any car, even with the thinnest wiring."
Obviously, the circuitry that prevents the setting of the bulb-out warning message didn't work. The stock setup is: 12V, 55W, 4.58 amps at roughly 2.61818 ohms. Asumming this is a typical 35 watt HID kit, it will most likely be drawing approximately 2.91 amps. If it detects a lower than spec'd amps, it may be what trips the E55 to turn the fog circuit power off. If someone knows the answer to this, please confirm.
Adam at EuroElites has my car for the week. Otherwise, I would have posted pics. I received both left and right fog bulb-out error messages.
I've left a voicemail for James this morning but have not heard back as of yet. I'm sure he will do the right thing.
Old Oct 23, 2007 | 12:49 AM
aganzon's Avatar
W211 E55 AMG
Just an update:
As I anticipated, James is going to fix the issue. Big props to James for responding to my queries tonight despite of what he is having to personally deal with regarding the major fire in San Diego.
James - I hope you, your family and your business makes it through the fires unscathed.
I'll give you all more updates when I get my car back from Adam on Friday.
Old Oct 26, 2007 | 04:43 PM
aganzon's Avatar
W211 E55 AMG
Just an update:
Got the car back from Adam yesterday and had a chance to fix the problem with the fog lights last night. James stated that the E55 supplies a -12V source to the fogs. To fix the problem, I just needed to reverse the wires on the supplied harness that connects to the factory 9006 connector. All is well. No errors or flicker. I'll post pics later when it's darker out. Quality stuff so far. The 6000K is a touch more purplish/bluish than the stock HIDs. Just a tad. It looks really good and far from looking like a ricer. It is also much much brighter than the stock halogen fogs.
Old Oct 26, 2007 | 07:05 PM
NGS_E55's Avatar
2013 CLS63 2004 S55
Thx for update, will have to make a trip down to SD after the smoke clears.
Old Oct 26, 2007 | 07:25 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I did notice that the power supply to my fog lights was reversed (brown +) in a short 6" plug to plug extension.I discovered this when I taped a 12V feed for my beast eyes. Glad you got yours working (I ordered mine 2 days ago).
The before HID, this is what 9006 silverstars look like.
BTY my city lights are from Pep Boys too. I tried all the others easily spent $35 for all the possible whitest lights, and still the Pep Boys "hyper white" bulbs were the whitest.
Old Oct 26, 2007 | 08:45 PM
christiaan's Avatar
E-550 Coupe 2010 SE
Hi,,do you have something for the City loght bulbs so they match the xenons? Or if i purchase the 6000k xenon bulbs for my bixenons, do you have some city lihts that match?
Old Oct 27, 2007 | 12:07 AM
  #32
jangy's Avatar
2015 S212
I'm sure he will. At least after reading this.
Old Oct 27, 2007 | 03:20 AM
  #33
aganzon's Avatar
W211 E55 AMG
Jangy - James is first rate. He followed up with my queries despite the fires there in SD. I'm glad all is well with him and his family. I sincerely hope you made through unscathed as well.
Old Oct 27, 2007 | 03:35 AM
  #34
aganzon's Avatar
W211 E55 AMG
Attachment 116627
Attachment 116628
As James said, it's plug and play quality kits...as long as you know the source wires should be reversed. The 8000K is a bit too purplish compared to the stock HIDs. IMHO 6000K is a better match.
Old Oct 29, 2007 | 01:48 PM
  #35
James@Creative's Avatar
Albert,
It was a pleasure working through this issue with you, I'm glad to see that all is well. Post some pics up when you get a chance.
Old Oct 29, 2007 | 01:51 PM
  #36
StealthAuto's Avatar
Cobra/E55
VERY nice James!!!
Old Oct 29, 2007 | 04:39 PM
  #37
aganzon's Avatar
W211 E55 AMG
Here are some lousy (I mean really lousy) pics
James - Here are some lousy pics taken using my phone. Aside from my camera (or is it the loose nut behind the camera ) malfunctioning, the last picture shows no malfunctions on the dash.
Attached Thumbnails How about a little Light-img00032.jpg   How about a little Light-img00033.jpg   How about a little Light-img00043.jpg   How about a little Light-img00041.jpg   How about a little Light-img00036.jpg
Old Oct 29, 2007 | 06:26 PM
  #38
blackcls63's Avatar
07 CLS63 | 06 SLK350
I installed an MTEC HID Kit on my slk350, and it was plug and play with no flicker and no malfunctions... kit is about 280$
Old Oct 29, 2007 | 06:34 PM
  #39
Tariq's Avatar
S500 W223 2021
Looks nice, but i dont think to change the Fog to HID,
I need to know about the bulb, in case if i need to change mine to 12000k do i need to change any other parts?
Regards
Old Oct 31, 2007 | 09:29 AM
  #40
jangy's Avatar
2015 S212
Glad you got your bulbs. That doesn't make a "first rate" shop. Wait until something goes wrong and see how they respond. All is well when the ball rolls straight, you padaywan
Old Oct 31, 2007 | 12:17 PM
  #41
Vic55's Avatar
Administrator
Jangy he never mentioned the word "shop". He spoke about James. I thought the dirty laundy had been aired?
Old Oct 31, 2007 | 01:59 PM
  #42
christiaan's Avatar
E-550 Coupe 2010 SE
Nice! are you going to change the little citly lights aswell?
Old Oct 31, 2007 | 02:04 PM
  #43
Regards
12000k for the fogs? or headlamps?
If you want the 12000k for the fogs, you'll need to purchase a 12000k HID kit for the fog's. the kit includes ballast and bulb color temp of choice.
Old Oct 31, 2007 | 02:07 PM
  #44
Vic,
I got the fog lights figured out if your interested in the E or the CL.
Old Oct 31, 2007 | 05:04 PM
  #45
BFOR3's Avatar
2004 E320
Hey Jason, with the CADesigns 1157 ghost amber Blink bulbs there is no problem with them working? I just tried to install LED 1157 bulbs and they wouldn't work at all? Are these LED turn sigs or just regular bulbs with a silver coating on them?
Old Oct 31, 2007 | 05:12 PM
  #46
aganzon's Avatar
W211 E55 AMG
No, I'm not planning on it. I actually like the color diff.
Old Oct 31, 2007 | 05:26 PM
  #47
aganzon's Avatar
W211 E55 AMG
Jangy - Did you mean "padawan"?
A young Jedi that undergoes intensive one-on-one training under a Jedi Knight or Jedi Master after graduating from the academy. As tradition a padawan of any species with hair grows a long strand of braided hair that is finally cut off during the ceremony of knighthood, when a Padawan becomes a Jedi Knight. A Jedi may have only one apprentice at a time, and is required to promote the current apprentice before taking another. However, this idea was scrapped in a way by Luke Skywalker due to the severe shortage in actual Jedi, as mentioned in Star Wars: Jedi Academy. Padawan is the name of a small town in Sarawak, Malaysia.
If you're going to call me names, please get it right.
Old Oct 31, 2007 | 08:42 PM
  #48
Tariq's Avatar
S500 W223 2021
Well I got 12000k bulbs and installed in the Headlamps , and my order was the color close to pink and white, but it looks blue, dose this mean i must change the HID rather the one i use in my car which is hella?
Old Nov 1, 2007 | 01:47 PM
  #49
JokerzWld's Avatar
2014 GL 350 on order
Owners: compliments to James at Creative Autoworks! The HID conversion enigma is SOLVED!
Motorwerks here in MI installed mine today and no error codes and they look great at 5000K.
Now, some wizard has to figure out how to hack the headlite switch so we can use the foglites in Auto lamp mode-Engineers?? Anyone? Joker
Old Nov 15, 2007 | 11:21 PM
  #50
Joker, have you hacked the switch yet???
Now that you have had some time with the new HID fog lights tell us your thoughts.
