Low oil?!
2005 E55
Low oil?!
I have been getting a message that says add one quart of oil at next fueling... what's going on? My E55 only has 35k miles on it?! Has there been history of bad sensors? I can not imagine this car is burning oil that fast already. please help.
2015 S212
I would take it in. It could be legit. Maybe they never filled it fully and so a little burn off could trigger it. Also, yes the sensor can go bad overtime, so that is a possibility. How many miles since the last change?
2003 E55 & 2014 GL550
My tech says that he has changed literally dozens of oil sensors over the years, but very few on E55's for some weird reason. Just changed mine and am not getting the error anymore.
Gotta be careful though. If you keep adding a quart when it's just a sensor, can be bad obviously.
NOW IF AMG WOULD HAVE JUST GIVEN US A DIPSTICK!!!!
CLS63
Do a search. It has happened alot around here. Mine even came one at 6k miles. These just seem to burn oil a bit. Again do a search. I don't think you have a problem. I have a dip stick
2015 S212
But the burning is an E63 issue, it hasn't been one for the E55s.
Keep in mind that we use synthetic and this it is thinner than conventional, but still my car burns very little but I do changes every 5K miles.
i'll second that...since i just had my second oil sensor replaced. sure it's a pita but the bright side is that you get a free oil change out of it (they have to drain the oil to change the sensor).
Sorry for the long post. Just wanted to say that it might be more to it then just faulty sensors.
