MJ50's W211 Mod Fever (OEM Retrofits)
#651
Super Moderator
bone stock E55 AMG
Turn ignition key to position 1 or 2.
2. Turn on Command.
3. Turn to Radio.
4. Press 5 (continue holding and wait 1 second).
5. Press 3 (continue to hold along with 5 key and wait 1 second).
6. Press 7 (continue to hold along with 5 and 3 keys and wait about 3 seconds).
7. A menu should appear. Scroll down and select "AMG211_ECE" option.
8. Switch off ignition, remove key and leave about 5 minutes before turning on again
2. Turn on Command.
3. Turn to Radio.
#660
2. Turn on Command.
3. Turn to Radio.
2. Turn on Command.
3. Turn to Radio.
#663
But if you have updated your COMAND 2.0 with 04/06 update this backdoor menu is gone and is only available through using SDS to access these features. Am I wrong in stating that?
#664
Super Moderator
bone stock E55 AMG
I was referring to the steps in this thread https://mbworld.org/forums/w211-amg/...d-command.html
but both CDCs had different part #s/labels...
my in-dash didn't play MP3s until i updated software...
not sure if ENG menu would've enabled MP3 playback both in-dash and CDC on mine...
#665
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Getting tired of hearing the same cd's over and over and would be so much easier if I could make mp3 cd's, since I don't have ipod integration capabilities or an iPod...
#666
I really hope this isn't true because I would have basically screwed myself haha. I had to update to use the newer nav discs... I guess I'll go check right now, kinda bored anyways.
#669
Ok, I just went down and tried it and I can still get into the ENG menu. Along with the 3 hidden softkeys. Phew.
#670
What Menu were you in?
Did this bring up the engineering menu where you can change MP3 settings or just the graphic display?
I'm curious.....
#671
Read through the thread I posted a few posts up, it'll answer all your questions. Yes it changes mp3 settings.
#672
Super Moderator
bone stock E55 AMG
Euro COMAND installed
just got Euro COMAND installed on friday nite...
simple DIY... VIM already enabled...
now works with OEM remote which i bought months ago... lol
this is 7039 model which doesn't have option to add TV tuner and RES...
bought it used and couldn't refuse the price...
