Summertime heatsoak blues!! Hey, do turbs suffer JUST like ours?
Old May 19, 2008 | 09:53 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Been literally bout 7-8 months since it has been 90 here and WOW what a difference that makes, and not the good way.
Dayum these cars just blow in the summer.
Sure wishing I had a very high hp N/A or the TT 6.2 yesterday that's for sure.
Question, I know turbs have to suffer like our cars to some degree, but is heatsoak at least a little less on a turb??
Sorry to keep repeating, but MAN yesterday sucked. Once warm, a Ford 500 was messing with me and then stomped it. I barely had enough power to overtake and pass him. Everthings fine with the car. Just all the mods makes a boatload of heat and she ain't happy when it's 90+.
Old May 19, 2008 | 10:11 AM
TKLEI14's Avatar
Turbonetics G35
My G35 is turbo, and it is affected by the heat, but probably not as much as the supercharger. The turbo runs off exhaust gases, so it is VERY hot normally.
The biggest problem when its hot would be intake temps, and the intercooler not getting enough cool air to lower the temps.
Old May 19, 2008 | 10:12 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Hmmm... Jackpro with the power you are running you need a bigger intercooler setup to stop your IAT's from going loopy. I would say the SLR style units are a must with anything north of 600 flywheel hp.
This is the reason you are cooking the IAT's so quickly. BTW do you have split circuit intercooler mod (as per evosport) or are you in OEM mode sharing with the engine rad? Might need to go split circuit with oversized rear mouted cooled water reservoir.
Larger and more efficient Intercooler mated with bigger heat exchanger is the holy grail on these cars....
You just have to look at the SLR for answers...
A turbo boosting the same boost as your S/C will be considerably more powerfull overall as its more efficient to pump than the S/C - with an obvious different power delievery. But if you had turbo's instead of a blower you would still suffer the same heatsoak issue with the intercooler limitation you have.
I heard somewhere the SLR uses approx 120hp to run the S/C at full power...
Old May 19, 2008 | 10:13 AM
JamE55's Avatar
Out Of Control!
A front mount CO2 might help.
Old May 19, 2008 | 10:24 AM
stevebez's Avatar
We need to sort out the friggin IC... its a POS.
Old May 19, 2008 | 10:47 AM
Jakpro1's Avatar
Thanks Steve
Yeah, she's all separated with Evosport exchanger and Johnson 90 pump. Wonder if maybe I should add a 2nd one or somethin??
Honestly may end up trying to setup something like Chiro did with the cooling tank in the trunk.
Also may look into CO2 sprayer as well just for fun runs.
Gonna do some datalogging this PM and see just how bad it is today. Another 90degree one today.
Will post up my IAT's and see what she looks like.
Old May 19, 2008 | 10:49 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Originally Posted by Jakpro1
Thanks Steve
Definitley check out the N-tercoolers.
Old May 19, 2008 | 11:52 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Thanks Steve
lets see what your data logging says and we'll talk. btw, consider yourself lucky with only 90's...we're supposed to hit 108f today!!!
Old May 19, 2008 | 12:00 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Thanks Steve
The bottleneck is the OEM IC, the next step is the SLR style IC.
Old May 19, 2008 | 12:14 PM
Jakpro1's Avatar
Out of all the money I have spent on mods, this truly has been the biggest regret. Should have went with those mods years ago honestly.
Klee I guess can get um done between 6-10K. Think that is what Cor quoted me last time I asked.
Old May 19, 2008 | 12:29 PM
stevebez's Avatar
There needs to be a better solution to the intercooler setup that does not cost an arm and a leg... the SLR is ideal but there should be something in between that may work as well - just need to see how to do it....
The SLR's a re super efficient as the flow is across a very long frontage of cooling - our cooler is small faced and long - means larger drop off in boost, and less cooling... SLR has probably 250% the IC volume than we have.
Just no room for an FMIC so guess we are stuck, unless you want to hack a hole in your hood and have a large air/air unit sticking out the top...
I was toying with the idea of flipping the S/C upside down - making room for one much bigger I/C on top. The associated plumbing would be a pretty decent mensa challenge though.
Also if you go TT (sans S/C) you got a nice big void where the S/C was for a proper I/C ... lose the primary cats to make space for the blowers and your set. I guess this is the best all in solution but it is a major change.
Old May 19, 2008 | 12:35 PM
hamann69's Avatar
E55 AMG
Its 92 down here in South Florida and the car is defently taking a beating with the heat.
Old May 19, 2008 | 12:37 PM
stevebez's Avatar
Was 11degC on Sat on my trip and the car felt like a friggin beast... the tranny reset really helps.
I wonder if this ECU reset does not reset a load limiter or something?
Old May 19, 2008 | 12:50 PM
higginsbeach's Avatar
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
90+ Bring it on BABY............Still friggin freezin here.................
Would you mind sending it our way please, except for this WEDNESDAY. I have BIG PLANS for WEDNESDAY!!!!!!!!!
Old May 19, 2008 | 02:27 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I was just going to say that we welcome the 90s because it's supposed to be 105 F today
The 63 suffers a dramatic and very noticable downgrade in power, but definitely not as much as the kompressors. It then stays a little more consistent than the 55s (I think)
Old May 19, 2008 | 02:53 PM
Murtaza's Avatar
C63S coupe, X5M
AMG needs to sort that **** out, 90degrees is not extreme weather; I don't hear the M5/6 guys suffering from heat soak
Old May 19, 2008 | 03:10 PM
Jakpro1's Avatar
Heh, they did sort it out, they DUMPED the Kompressors.
Not the solution we were hoping for though.
Hoping that this company known for being first in innovation has the engineers working OT on the turb cooling systems for the next set of engines.
Old May 19, 2008 | 03:16 PM
MB_Forever's Avatar
Actually they do..... but just not as much as MBs. We had a couple of M5s and M6s on the track with us during a few of our track sessions and they showed difference in performance as well.
Old May 19, 2008 | 03:17 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
VRUS
is supposed to be making some top mount intercoolers right?
Old May 19, 2008 | 03:20 PM
blackbenzz's Avatar
haters crazy
Turbo cars suffer less from heat soak than sc cars although they still do experience heat soak. Turbos will make more power than a sc on the same engine as well since it runs off exhaust gas and there is no parasitic loss for the engine trying to turn the pulley. Thats why eveyone should have at least one turbo on their car
Old May 19, 2008 | 04:33 PM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
Talk is one thing and data & fact are an other...
Cooling on stock cars DOES not increase performance, it maintains consistency longer, if it is ever breached in the first place...
Lots of people saying things, with out numbers to back it up I believe.
Jackpros car is not stock and has a butt load of mods...its natural to assume it will be running hotter then stock. How hot is yet to know, thus get data logging and try to get a few test seniors down on paper to right down the numbers you get.
Secondly all cars suffer from the heat, some more then others.
Jack you got Evotech big *** pulley yes?
Old May 19, 2008 | 04:39 PM
Jakpro1's Avatar
Well it's official, this car has now surpassed the wife in it's ability to give me extreme pleasure one day, and then make me near suicidal the next.
Reset the ECU last night via battery disconnect. Sure enough, COMPLETELY different car today. Ferocious and mean again even in the summer heat. As I did a couple of higher R runs to get her piping hot, I could feel performance dropping like yesterday, but totally different powerwise from yesterday.
I honestly could not even lightly squeal the tires yesterday from a redlight. Just slowly boooooooggged it's way up in R's.
Today, the devil again.
All kidding aside you guys, what's your thoughts a battery quick disconnect from like a Jegs or Summitt. Maybe I just reset the gosh darn thing couple of times a week for years of possessed driving.
Old May 19, 2008 | 05:03 PM
Zod's Avatar
Zod
JAck do you use your peddle shifters at all?
example S mode and down shift to be in power band via steering wheel shifts, then let her rip?
oh and whihc pulley?
Old May 19, 2008 | 05:14 PM
Jakpro1's Avatar
Nah, can't on the 03's. Wheel shifts only work in M mode.
Bummer on the 03's.
Wondered a bit if it was my pedal sensor, but time will tell.
Maybe I will swap it out just to be safe.
Old May 19, 2008 | 08:49 PM
chiromikey's Avatar
my car will go into granny mode and not downshift if i'm too easy on her but after just a few romps of the throttle, she comes right back. i can't believe you should have to go through this much trouble...
does the sneaky ecu reset work for you? that would be much easier than disconnecting the battery every few days!
