Tires sizes for 20" ......... [245/30 - 275/25] OR [245/35 - 275/30] ?
Old Feb 26, 2009 | 12:04 AM
RonnieRenaldi's Avatar
SL55 AMG & BMW F10
Question Tires sizes for 20" ......... [245/30 - 275/25] OR [245/35 - 275/30] ?
What are the pros & cons with either of these?
[with diameters]
Front 245/30/20 - 25.8"
Rear 275/25/20 - 25.4"
OR
Front 245/35/20 - 26.8"
Rear 275/30/20 - 26.5"
Stock tires:
Front 245/40/18 - 25.7"
Rear 265/35/18 - 25.3"
Old Feb 26, 2009 | 12:10 AM
Chadillac2000's Avatar
2003 E55 AMG
What do you have planned now?
Old Feb 26, 2009 | 12:13 AM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
I was told that the 245/35/20 on the front will rub if lowered. So Im running the 245/30/20
Old Feb 26, 2009 | 12:20 AM
Neoii's Avatar
e500
30/25 combo to keep the OEM diameter. The other size is 1" too tall, although some here do run the taller size.
In general, I like the 235/275 or 245/285 combos. I am currently using the 245/30 285/25 combo with my 20s.
Old Feb 26, 2009 | 01:01 AM
SL55 AMG & BMW F10
Nothing
Old Feb 26, 2009 | 01:07 AM
2003 E55 AMG
Originally Posted by MPRESIV
Nothing
Haha sureeeee. I knew as soon as I saw your thread on the lowering module what was next.
Old Feb 26, 2009 | 01:43 AM
PerisanGodFatha's Avatar
is Sick as Fu*k
this is true...
the 245-35-20 and 275-30-20 are the best ride/ handling for a 20" wheel imo...but 245-30-20 and 285-25-20 look the best....if you run a 245-30-20 your car will not rub lowered but it willl for sure rub with a 245-35-20 I know this because I screwd up my fender in the begining stages of modding my car.
hope this helps...and good luck
Old Feb 26, 2009 | 02:17 AM
NSX2NV's Avatar
03' E55 Techtite Grey
It depends on your offset. I run 245/35/20 and 275/30/20 with no rubbing. My car is slammed with half the tire tucking with no problems what so ever. I have just ordered new rear tires and I'm going with 285/30/20 instead so the tires will match better. Right now the rear tires sidewall is shorter but with the 285 in a 30 series it will be only .25mm difference between the two.
Here are the sizes broken down.
245/30 = 73.50mm tall sidewall
245/35 = 85.75mm tall sidewall
275/25 = 68.75mm tall sidewall
275/30 = 82.50mm tall sidewall
285/25 = 71.25mm tall sidewall
285/30 = 85.50mm tall sidewall
You have to ask yourself what you want. The higher sidewall will give you a more comfortable ride. Technically the car will be higher off the ground but the tire will tuck more into the fender and quarter. But with the lower it will sit lower to the ground. Also a big thing to think about is how are the roads you travel? If they are bad you're going to want a higher sidewall so you don't bend a rim.
Hope this helps.
Old Feb 26, 2009 | 04:08 AM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
your best bet
You can run 275/30/20 in the reat with no problem,
I say the best ride is 245/30/20 and 275/30/20, the specs will be off but there is a big difference in ride quality when you go up a size
Old Feb 26, 2009 | 07:52 AM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
I run BF Goodrich g-Force T/A KDW 2
Front: 245/35/20
Rear: 285/30/20
And have not one problem. There is very little gap and no rubbing. My car is not lowered and my rims are:
Front: 20x9 - 38 Offset with a 7mm spacer
Rear: 20X10 - 38 Offset with no spacer
Old Feb 27, 2009 | 01:26 AM
storm's Avatar
Mercedes,Porsche etc
[quote=MPRESIV;3377225]What are the pros & cons with either of these?
[with diameters]
OR
IF you use 20" rims you must do
every inch you go above 18 you drop 5% aspect,, to keep the rotational mass within spec, and not to throw off your speedometer
and not to rub..
if you go with the 35/30's it will trow off the speedo, and also increase the rotational mass more, making braking suffer slightly
not to mention your dealer will start blaming any suspension issues you have on the wrong size tires and wheels,. so
do the
good luck
Old Feb 27, 2009 | 01:32 AM
storm's Avatar
[quote=NSX2NV;3377473]It depends on your offset. I run 245/35/20 and 275/30/20 with no rubbing. My car is slammed with half the tire tucking with no problems what so ever. I have just ordered new rear tires and I'm going with 285/30/20 instead so the tires will match better. Right now the rear tires sidewall is shorter but with the 285 in a 30 series it will be only .25mm difference between the two.
yeah but it will also throw off the speedo, which throws off all the speed sensors and ecu slightly, and abs, and increases the rolling diameter
and rotational mass too much which the computers dont take into acccount, and it also stresses the brakes more and reduces stopping distances..
the proper way, and any tire tech, or merc tech will tell you its a + 2 size upgrade and too keep the computers and brakes and speedo in line
you must use
sure the other works, but your car will be slightly off,, why would you want that,.
and I was just at mercedes today talking to their master head mechanic
about this, cause he was laughing at all the idiots that put 20-22 inch tires on the cars, with the wrong aspect ration and when they have problems etc with them..
just a FYI
Old Apr 27, 2016 | 09:49 PM
benznewcomer's Avatar
porsche
i thought the proper size for the 20 inch wheels is 245/30/20 and 285/25/20
