List of availible STAR changes?
I'm taking my car in for the dealer to check the IC pump and I was wondering if anyone had a list of changes that can be made via STAR that I could take with me? Thanks!
and BTW.. I did a search and it was utterly useless.. :confused: |
Lower Airmatic suspension
10 fan mod Lighting options |
Thank you!
If you are not into doing the "sneaky ecu" reset thing, have him clear your tranny adaptations.
You'll love that one!!!! If you already do sneaky reset, nevermind. |
Originally Posted by shardul
(Post 3496078)
(Post 3496078)
Originally Posted by squidj
(Post 3496871)
Will doing these changes (10 fan mod) with STAR mess your tune at all?
What EXACTLY is the process to lower the car via STAR? Does anybody know? What do I do to tell my tech how to do it (he would be totally down) without him looking at me like I'm crazy?
Originally Posted by Eleanor Owner
(Post 3515164)
(Post 3515164)
Reset the ride height to be within the voltage range. Set your inclination angle to (5.5 fronts and -1.5 rears). This will give you about 1.8 drop in the front and 1.0 in the rear. If your body has access to an alignment rack, then have him measure the inclination angles while the car is on the rack after you've adjusted the voltage/height. If you don't have access to an alignment rack, then you can use the #s I set above. |
