Aux. Heat Exchanger, Split Cooling - Done PICS
Old Sep 5, 2009 | 07:31 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Will provide a write yup and IAT data later on. here are the pics. I bought this set up from PTE for a killer price. It is an aux heat exchanger which is in series with the OEM heat exchanger and a Meziere WP136 pump, got rid of the CM30.
By shardul, shot with BlackBerry 8330m at 2009-09-04
By shardul, shot with Canon PowerShot S2 IS at 2009-09-05
Old Sep 5, 2009 | 09:00 PM
TopGun32's Avatar
looks very nice..
I like the end tanks of the HE.
Your testing would highly be dependent on the ambient temps.
I'm hoping that splitting the system can reduce a bit of that spike after 100mph
Old Sep 5, 2009 | 09:34 PM
RacerX0911's Avatar
nicely done!
Old Sep 5, 2009 | 10:30 PM
jangy's Avatar
2015 S212
nice writeup!! Interested to see the IATs. I was told the power steering reservoir was too small for this application but I see so many running it with success.
Old Sep 6, 2009 | 08:08 AM
Full Throttle's Avatar
CLS55 AMG
It appears like there is room for one really thick core. As opposed to having one block the other. Do you think that by blocking the OEM H/E you will have diminished results? It does not look like much are will reach the primary H/E. Awesome right up and thanks for the review. Please post before and after IAT logs when available.
Old Sep 6, 2009 | 12:02 PM
shardul's Avatar
i took it for a brief run yesterday and the results were very promising. i still have to bleed the air out of the system
Old Sep 6, 2009 | 02:34 PM
shardul's Avatar
under normal hwy driving conditions my IATs were 9 about ambient. it was 91 outside my IATs were between 98-100
will go and do some 0-100 pulls tommorrow
Old Sep 7, 2009 | 12:46 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
As usual shardul, very nice write up.... and great pictures
Old Sep 7, 2009 | 01:27 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
AFAIK, most of the gains come from simply separating the systems - thereby preventing your IC fluid from comingling with 195*F engine coolant. The size of the additional reservoir is an incremental benefit, with larger typically being better within reason.
shardul, nice pics!
Old Sep 7, 2009 | 11:26 AM
TopGun32's Avatar
In my set up I hoover around 15 to 20F above temp in 90+ degree heat. Last 2 weeks around here (So Cal) they were blazing hot and I was able to do some worst case data log.
The worst day was around 108F here in Ontario.
Old Sep 7, 2009 | 02:16 PM
shardul's Avatar
Did a 40-110 pull in 3rd. Max IAT was 127 in 89 F ambient temp.
Under normal drivning conditions my IATs were again 8-10 over ambient.
So I am guessing the aux heat and meziere pumps works very well.
Old May 14, 2010 | 09:00 AM
ahmad0658's Avatar
Brabus K8 E55 05
I want to highlight something,
Your set up is good and the idea is great specially if there is an improvement than the stock set up, but the front new aux HE won't block the air from passing to or the original HE at least reduce it?
As I said, overall I think it is very good set up specially if there is improvement in term of cooling.
Old May 14, 2010 | 09:05 AM
shardul's Avatar
my IAT number speak for themselves
Old May 14, 2010 | 06:57 PM
Ohbev's Avatar
E55 AMG Kompressor
Did u have the cut the front bar at all to fit the aux H/E
Old May 14, 2010 | 10:41 PM
shardul's Avatar
no cutting involved
Old May 2, 2016 | 04:31 PM
AMG4FUN's Avatar
2014 Mercedes Bnez GL500, 2016 Mercedes Benz CLA45 AMG
Was there a write up for this?? If not, where can I find one like this?
Old May 2, 2016 | 05:08 PM
shardul's Avatar
i dont think so anyone sells this kind anymore. Only a total of 4 were made by Active Autoworks
Old May 2, 2016 | 05:12 PM
AMG4FUN's Avatar
OK thanks. I'm really looking for a write up for the Evosport cooling upgrade, which looks similar to this, but haven't been able to find this either.
