reset ecu
Old 09-06-2009, 03:42 AM
Ohbev's Avatar
E55 AMG Kompressor
reset ecu
I dont want to do the sneaky ecu reset i want to reset all the ecu.
Do i need to go to my mb dealer what else can i do to reset the main ecu.
i feel the car is not going that good maybe pulling a little timing and stuff like that. Want to reset the ecu
Old 09-06-2009, 03:50 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
If the car is pulling timing, there maybe very important issues that you need to consider: bad quality fuel, too much heat, knocking, etc...
I think you can re-set the ECU without going to the dealer, but you may need to go to someone who has access to STAR diagnostic software.
Old 09-06-2009, 10:27 AM
jdeastbay's Avatar
2005 E55 / 2008 E63
My local guy who does my non warranty work resets all settings for me. The car is a true monster once reset, like a dream. My biggest complaint is the car is not allowed to stay there, soooo frustrating which we all know well. It looks like the 2010 e63 has the amg button allowing you to stay aggressive, we'll see if it really works.
Old 09-06-2009, 02:01 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
i would love to see tuners supply us with an obd2 option to reset everything ourselves!!!
Old 09-06-2009, 09:09 PM
Ohbev's Avatar
E55 AMG Kompressor
normally i get up to 80kmh then put my foot in it that car kicks down and sound very loud and shoots forward very fast and hard.
But the past few days its not made that very loud kick down and went forward hard its not dead slow but its not super fast.
maybe i should let the fuel run out then get new fuel and reset the ecu
Old 09-07-2009, 12:37 AM
MB_Forever's Avatar
We can do this right now through OBDII port but we have to have the expensive STAR diagnostic software
Old 09-07-2009, 12:44 AM
OJPAMG's Avatar
2005 E55 AMG
Might be time to check the intercooler pump
Old 09-07-2009, 03:18 AM
chiromikey's Avatar
yes...but my point is we should be able to own a simple inexpensive tool to do this ourselves. maybe something similar to renntech's rat device where we can just plug it in and let it erase our adaptives!
Old 09-07-2009, 04:14 AM
ShangoAshe's Avatar
2020 AMG GT-R PRO
i think your better off just resetting your tranny ECU first, and see how that feels!
my experience with tranny ECU reset was definitely NIGHT AND DAY!
give it a try, before going to all kinds of places to reset when you can reset your tranny your self!
Old 09-07-2009, 04:22 AM
chiromikey's Avatar
two totally different things...
Old 09-07-2009, 04:27 AM
ShangoAshe's Avatar
2020 AMG GT-R PRO
woops my bad :p
is this like the engine ecu?!
Old 09-07-2009, 04:43 AM
Ohbev's Avatar
E55 AMG Kompressor
even if my car still has some power could the ic pump be still working but on its way out ? like the ic pump is not working good?
Old 09-07-2009, 04:44 AM
chiromikey's Avatar
yep, engine ecu, more specifically timing and fuel adaptives.
Old 09-07-2009, 04:55 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
so this is totally different than doing the sneaky ecu resets?
so i guess the sneaky reset is just a partial reset and if we had the star diag then we can do a full reset, is that correct?
will doing this FULL ecu reset through the star diagnostic system erase my kleeman flash? (or future PC flash)
i would like to try and get the full reset done if it allows me to keep my kleeman or pc flash.
Old 09-07-2009, 04:59 AM
chiromikey's Avatar
it won't erase your tune and this isn't something that most people will need to do but it could be very useful as a diagnostic tool.
Old 09-07-2009, 05:03 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
what are the benefits of doing this full reset over the sneaky one then?
i sometimes feel that the sneaky one does not do a whole lot.
Old 09-09-2009, 12:04 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
so if dealer does a reset, it wont erase PC flash tune ?
Old 09-09-2009, 01:07 AM
chiromikey's Avatar
a "reset", no...a "reflash", YES!
Old 09-09-2009, 07:20 PM
Timeless's Avatar
2005 E55 ///AMG
They should incorporate this into something like the Sprintboosters. Every time the car starts it clears the settings...or might be adjustable to every so many times.
Old 09-09-2009, 09:20 PM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Can`t you erase the adaptives by ??
Turning key to the ON position and then disconnect battery. Let sit for 30 minutes, turn key off and then re-connect battery?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 09-09-2009, 09:55 PM
buckeyewalt's Avatar
E63,,,not any more,,,BMW X5 50i
Somewhere on this board, there was an reset done on the 63 engine that is a little different than the one done on the 55 engine. The guy who did the reset was I think from Germany and he said to reset the 63 engine,,,,make doors are closed, windows up and radio off. Turn the key to the second click and hold the accelerator peddle down for 45 seconds.......turn the key off and then take the foot off of the gas and wait 2-3 minutes before starting the engine, in the car with the doors closed and the radio off. The only difference is the 45 seconds vs the 5 seconds for the standard ecu reset. While I have no real proof (timing slips or dyno numbers to prove anything)...the butt dyno tells me something indeed has been changed. I am asking other 63 engine guys to confirm this. I tried to find his post, but unable to do so.
Old 09-09-2009, 09:59 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
My Indy mechanic did a reset for me and was definitely a major difference. Then I got back into traffic and all the usual crap, and it 'adapted' and lost it all.
+1 that we need some inexpensive OBDII device that we can do a quick adaptive reset anytime.
Old 09-09-2009, 10:02 PM
I'am telling you,,,,,,,,try this next time. I was totally convinced that this is the corrrect way to do the 63 engine. It only takes 2-3 minutes of your time. If it don't work,,,don't do it again,,but I'll say it again,,,there was a marked difference!
Old 09-09-2009, 10:29 PM
220S's Avatar
Buckeye, look at Mikey's posts #10 and #13.
What you're describing is for the TCU. That "reset" thread with the E55 was about resetting shift points. Sounds basically the same that you're saying for the E63.
We're talking ECU. That takes a Star diagnostics reset, afaik.
Old 09-09-2009, 10:40 PM
jangy's Avatar
2015 S212
The only way I know of is to unplug the battery for 2 days.
A gizmo that resets the adaptations (ECU and Tranny) at each startup would be a SWEET mod.
All the more reason to buy a STAR unit....
Quick Reply: reset ecu
