Brake Flush Cost
Old Nov 23, 2009 | 11:07 PM
Shadow5501's Avatar
Car free at the moment
Brake Flush Cost
Hi Dudes. New owner of a 2006 E55 here. Not new to Benz; this is my 6th one in a row - a 123, two 124s, two 210s, and now a 211.
Got a question. As is usual when buying a used car, I went through the records to identify any deferred maintenance that needs catching up. The only item on this car was a brake fluid flush. I had a local well renowned indy shop perform the service along with mounting tires and an alignment. They charged $377.09 for the brake flush.
I am in shock.
I am under the impression changing the brake fluid on the 211 AMG is pretty much the same as any other Benz with SBC. Put the car on a lift, hook up the SDS, and bleed each corner. Yeah, it has two bleed nipples on the front calipers, so charge me an extra 10 minutes.
How much are y'all paying?
Old Nov 24, 2009 | 12:06 AM
lowprofile's Avatar
E55
Two different dealerships quoted me $120-$125 for the brake fluid flush.
Old Nov 24, 2009 | 12:27 AM
jicl55's Avatar
2003 cl55 (sold)
I am in shock.
Paid $70 at an indy shop for my brake flush.... seems like they saw $$$$ when you walked in
Old Nov 24, 2009 | 12:25 PM
Shadow5501's Avatar
Following up to close off this thread. I had a chat with the shop foreman today. He indicated they do the brake flush by the book; there are several steps required to fully flush the system including the SBC unit. The process requires a few hours of time.
If you paid only ~$125, then you didn't get the entire job. For that price, they just hooked up a pressure bleeder and did all four corners of the car. Better than nothing, but not doing it right.
Old Nov 24, 2009 | 12:31 PM
dkallencat1's Avatar
Dealer quoted me 150.00
Old Nov 24, 2009 | 01:43 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Your 06 doesnot have SBC it was discontinued in 03 or 04.
Old Nov 24, 2009 | 02:09 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
if the dealer quote $150 .... then the job is about $150, dealer always goes by the book IMO. Dude, u paid too much !
Old Nov 24, 2009 | 02:11 PM
Quadcammer's Avatar
96 and 08 911 turbos
Inaccurate. SBC was discontinued in 2007 I believe
TTMotorsports's Avatar
Whatever we're tuning!
The SBC brake system needs to be done with SDS and it does take a lot of time.
Even though that price is a little high it seems to have been done correctly.
Good luck with your new beast!
Old Nov 25, 2009 | 12:53 AM
bce63's Avatar
e63
I just had it done today on 2007 e63. 52.90 parts 87.50 labor 140.40 total. canadian
Old Nov 25, 2009 | 07:14 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Had mine done last week at the dealer, $189. The tranny service was $400.
Old Nov 25, 2009 | 10:11 AM
MBTEK's Avatar
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
IN ORDER TO DO A CORRECT BRAKE FLUSH ON ANY SBC CAR YOU NEED TO HAVE A SPECIAL ELECTRICAL BRAKE BLEEDER PUMP THAT IS ADJUSTABLE ALONG W/ AN SDS.ALSO A BATTERY CHARGER SHOULD BE CONNECTED TO THE BATTERY.ON AMG CARS THE WHEELS HAVE TO COME OFF SO YOU CAN BLEED/FLUSH BOTH SIDES OF THE CALIPERS AND NOT RUIN YOUR WHEELS.MOST PLACES JUST CONNECT AN OLD SCHOOL BLEEDER AND DO A CONVENTIONAL FLUSH,WHICH MEANS LESS COST.ALSO WHEN YOU GET THIS SERVICE DONE THEY SHOULD BE CHECKING IF YOUR SBC NEEDS TO BE PROGRAMMED AND HOW IS THE SERVICE LIFE OF THE UNIT.PROGRAMMING SHOULD BE COVERED UNDER ELW/CPO/BASE WARR. NORMAL CHARGES FOR A FLUSH SHOULD BE 1-1.5 HOURS,BUT HAVE THE SERVICE LIFE CHECKED FIRST,THAT WAY IF YOU NEED A NEW SBC PUMP,WARRANTY PAYS FOR THE FLUSH.211 SBC ENDED IN 06,07 AND NEWER HAVE ABR.
Old Nov 25, 2009 | 10:15 AM
teolax's Avatar
2007 E63
I just paid $400 for my service C which was a brake fluid flush, cabin filter, and oil change.
Old Nov 25, 2009 | 10:35 AM
emoving's Avatar
That's a good price, you figure the oil is $150 the cabin filter is $50 so you got the brake fluid for $200. Plus MB did the work!
Old Nov 25, 2009 | 11:55 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i just DIY...
Old Nov 25, 2009 | 01:56 PM
teolax's Avatar
2007 E63
They wanted $600 at first!! I told them they were nuts and that I would go to an indy and he agreed to meet the price. It's a different world out there now. The stealerships want to do all they can to stay in the customers good graces...
Old Nov 25, 2009 | 02:33 PM
emoving's Avatar
That's also why brake rotors that used to cost $800 a piece are now $110 form the stealership! Hell it's almost like maintaining a Ford Tarus these days.......ok well maybe not that cheap!
Old Nov 25, 2009 | 02:39 PM
CharlyE500's Avatar
FYI, I paid my tranny service for $270 at Mercedes Anaheim dealer.
Not sure if its complete flush or...
Old Nov 25, 2009 | 02:41 PM
emoving's Avatar
Opps, sorry my bad, that included an oil change so I paid @ $270 as well.
Old Nov 27, 2009 | 06:28 PM
Shadow5501's Avatar
Thanks for all the input.
The shop I that charged $377.09 for my brake flush is Autoscope, in Plano, TX. I have seen that they post on this forum (and are a sponsor? - no sure.)
As always, the quality of their work is superb. However, if they are going to charge far above dealer rates, I think I'll just go to the dealer, save some money, and get a loaner car to drive.
Old Nov 27, 2009 | 07:06 PM
emoving's Avatar
LOL I have found that routine maint. is close to the same price anywhere and I would rather have the MB recipt. Plus like you said, you get a loaner!
Old Nov 27, 2009 | 07:30 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Indianapolis dealership quoted me about 277.00 I believe. Lafayette couldn't even do it! The dealer also suggested that this should be preformed every two years. It showed up in the print out that I made the dealer give me when I can my B service done. The Lafayette dealer didn't even suggest having this done because they didn't have the proper tools to complete the job.
Old Nov 28, 2009 | 12:06 AM
bce63's Avatar
e63
just for clarity, Mercedes canada shop
perform brake flush,remove wheels, bleed inner and outer amg caliper chambers 140.40
perform teraclean fuel injector flush 199.95
perform service A, filter, mobil 1, cleaning compound, washer solvent,fuel additives 315.08
Total 754.41 at the dealer. I hope this helps.
Next week keyless door handle replacement (warranty), and brake pads. No rotors needed
I hope this helps some
