HOW TO: Valve Seal Replacement
Rating: Thread Rating: 4 votes, 5.00 average.
Old 01-04-2010, 10:13 PM
kjlindgr's Avatar
Viking War Ship
I've been chasing some oil consumption gremlins in my 54K mile E55 for a while now. Having a car that burns a quart of oil every 1000 miles might be "within spec", but it still pisses me off. I'm used to the Japanese import cars that burn nothing...ever. The tell-tale puff of smoke at startup lead me down the path to replace valve seals as a place to start. If that doesn't solve issues, a motor pull and ring replacement might be in the works.
Let me start out by saying that this is not a job for the faint of heart. It would literally be easier to yank the engine and do this outside the car. It's a VERY time consuming project and I spent close to 10 hours on it in my spare time and I'm no n00b with a wrench. Space is tight, and lots of specialty tools are needed:
TOOLS NEEDED:
* external torx set
* regular torx set
* cam lock guides
* valve seal pullers
* 12mm socket (aka valve seal drift)
* 27mm socket to rotate crank
* pan to drain coolant into
* rags...lots of rags
* valve spring compressor
* 17mm box wrench
* magnetic pickup tool
* cylinder pressurization tool-thingie
* probably some other sheit I'm forgetting
Start the fun by removing stock airbox, coil packs, and spark plug wires. Go ahead and remove one spark plug per cylinder...only one though:
Next, remove the valve covers and attached breather tubes:
Rotate the crank clock-wise to 40 degrees TDC (marked on the underdrive pulley) and attach the cam sprocket locking plates. They are the shiney things with all the camera flash glare marked with the red arrow:
The cam sprocket plates help keep the cams in a position where they won't interfere with the pistons...and to help aid in timing the motor afterwards.
Next, remove the cam rocker bridge:
I removed JUST the passenger side camshaft as well. The factory service manual says to remove both, but I didn't find this necessary. Plus, good luck getting an E18 socket on the driver's side cam sprocket with the oil filter housing in the way. Thanks Mercedes.
Before you can remove the cam shaft, you need to remove the timing chain tensioner. The timing chain tensioner is conveniently located behind the alternator...so that needs to be removed to gain access.
Next comes the fun part. That was lie actually. The supercharger needs to come off. The reason for this is that it's completely in the way for using the valve spring compressor tool. You can try it without, but only the front-most intake valves will be accessible.
Supercharger in place:
Drain the coolant since the air-water intercooler is attached to the supercharger. There's a plug on the side of the radiator:
Fuel disconnected, rail removed, throttle body removed and then we have a 113 engine sans supercharger:
Now it's time to pressurize the cylinders. This prevents the valves from dropping into the cylinder when the springs are removed...also allows you to get the springs off the valves. Put the cylinder pressurization tool into the one open spark plug hole. The second plug should still be in place. The manual says to put the piston you are working on at TDC. I found this to be a futile effort since the crank just wanted to spin anyway. I just let the cylinder sit at BDC (bottom dead center...if that's even a term) and it all worked fine:
Valve spring compressor tool in the case:
Valve spring compressor tool in use:
With the spring compressed, use a little magnetic pick-up tool to carefully pick out the retaining locks. There are two per valve and they each form a half-circle around the valve stem holding the retainer and springs in place.
With the locks and retainer off, you now have access to the valve stem seal:
Grab your valve stem seal pliers and pull the old one off:
Here's how the new seals come. You get 4 seals per package and 2 condoms. The condoms are used to prevent the milled end of the valve stem (and the locking ring) from damaging the valve seal while installing. I put a little Permatex assembly lube on them prior to installing just for added lubrication:
Condom first, THEN lubed up valve seal. Use a 12mm deep socket as a drift to push the new valve stem seal onto the valve guide:
Here's where things got even more retarded. Since space is so cramped inside the engine bay, I needed to make this funky extension thingie for the spring compressor so I could get to the exhaust valves. I used a scrap piece of flat steel stock, drilled some mounting holes, then drilled and tapped a series of holes for the compressor to use. Again, this would be easier to do with the motor out of the car:
With all of that nonsense, you're done. Install things in reverse order making sure to tighten per the factory service manual torque specs. Timing the engine is critical as well so make sure you also consult the FSM for this procedure also.
The car is "put away" for the winter so I'll have to wait until Spring to tell if it helped my oil burning issues. Hopefully this guide showed everyone how much of a pain in the *** this whole thing is and not to attempt it without copious amounts of top-shelf gin.
Old 01-04-2010, 10:34 PM
Bellevue_E55's Avatar
2006 Mercedes E55
Your a PIMP and a Mad Man!
Very impressive. I am in awe.....
Old 01-04-2010, 11:15 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Good job, great pics, nice write up, hope that valve stem reseal solves the oil consumption.
Old 01-05-2010, 12:07 AM
bobgodd's Avatar
2004 E55
My car burns a quart of oil every 1000 miles also, and it's extremely annoying. Wonderful write-up and thank you for your efforts!!
Where can you find info on timing the engine after this process is complete?
Old 01-05-2010, 02:44 AM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
I feel like we have another Finney in our midst! Nice job tearing into the M113K!
Old 01-05-2010, 07:40 AM
slownrusty's Avatar
'06 E55 K2
Fantastic write-up and kudos for the bravery to tackle this at home. Very ingenious use of flat stock to combat the tight space. I applaud you!!
Yasin
Old 01-05-2010, 08:34 AM
lowprofile's Avatar
E55
Excellent technical post, thanks for sharing. Can you elaborate more on what you found? Did the old seals feel hardened? The replacement seals seem a bit beefier than the original, are these from MB or did you outsource some generic seals? What model year engine are we looking at? Last, did you find excessive oil in the intake when you removed it?
Again, thanks for taking the effort to photograph and document your R&R.
Old 01-05-2010, 08:46 AM
PTE
PTE's Avatar
05 ML-500 , 03 CLK5.5 AMG has left the Garage
You are so Lucky
Man what a great Job! you are SO LUCKY you did not break the cylinder air pressure. When collapsing the valve spring to remove the retainer keepers. Then rotating the crankshaft back & forth to find TDC with a loose timing chain. I can see that you used all the right timing plates to get the valve timing back in order.. Well anyway , Nice write up & Pictures, You did a great Job. with some innovation for those hard to get to Spots.
Cheers _PTEngineering
Old 01-05-2010, 09:35 AM
kjlindgr's Avatar
Viking War Ship
Thanks for the kind words gents. The old valve seals didn't look too terrible, but they were showing some signs of fatigue. I'm not 100% convinced that this is the only thing going on inside the motor though.
The valve seals were purchased from www.europartsamerica.com and are an OEM equivalent. They are $4.11 a pack, and you need 6 packs. The total cost of the parts is FAR outweighed by the work you put into it. Lame, but that's the way these things go.
The engine is out of a 2003 E55 so it's still the same 211.076 model 113.990 engine. There wasn't much if any oil in the intake. There was some coming out of the PCV valve on the driver's side, but this will hopefully get trapped with a catch can. Not sure if it's excessive or not, but only time will tell how fast the catch can fills up. If I find it's pouring a lot into the can, that's usually a good sign of rings.
Here's a note on timing I found on the interweb. It's pretty standard, but you need to make sure that the timing marks on the cams are aligned with the 40 degree TDC mark on the crank as shown here. After you get things the way they look here with the tensioner installed, spin the crank a few times just to make sure you haven't jumped a tooth on the chain and it comes back around looking exactly the same.
Old 01-05-2010, 09:51 AM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
God how I live for this stuff
Gret write up, and I love to see owners getting their hands dirty
GREAT JOB my friend
Old 01-05-2010, 03:14 PM
TopGun32's Avatar
job well done!
btw: I wanted to change my valve cover gaskets on my C32. What is the correct process to apply the gaskets?
Old 01-05-2010, 05:37 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
WoW, how many hours takes to do this job ?
Old 01-05-2010, 06:16 PM
kjlindgr's Avatar
Viking War Ship
Changing valve cover gaskets should be pretty easy:
1. Remove air pipes and air box
2. Disconnect and remove coil packs
3. Remove valve covers
The seals just push in and out so they are pretty easy to change once you've got the valve covers off. I changed mine out when I was putting everything back together.
Old 01-05-2010, 08:55 PM
TopGun32's Avatar
any particular sealant or silicone on the gaskets?
thanks!
Old 01-05-2010, 09:44 PM
kjlindgr's Avatar
Viking War Ship
Nope, they are rubber gaskets so they seal just by contact. No silicone gasket maker or any of that jazz.
Old 01-05-2010, 09:52 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
nice write up
Old 01-05-2010, 11:08 PM
O-55's Avatar
2005 E55, 2009 VW GLI
hopefully this takes care of your issue. great work and thanks for sharing.
Old 03-25-2011, 10:42 PM
bobgodd's Avatar
2004 E55
Did this solve the oil issue??
Old 03-26-2011, 02:30 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Great write up. This is one of those jobs I detest with a passion. I would almost sell a car before going through the effort-but that is me. Just no time these days.
BC928 (02-03-2020)
Old 04-06-2015, 06:02 PM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Old thread revival but I do have a pointed question for anyone who has experience tearing apart this motor. As I've never worked on this motor this deeply before, with the cams removed such as this and having to rotate the the crank to pressurize the cylinders, will the chain and sprockets rotate with the crank as I spin it or am I better off removing the chain completely and re-timing everything upon reassembly?
Old 04-07-2015, 06:29 PM
WANTED!!'s Avatar
Bueller??? Bueller??? Anyone??
Old 04-07-2015, 06:42 PM
Max.H's Avatar
E55
I would not remove the chain completely. If the cam is removed and sprocket is still attached which it should be and all timed. It should move also with the crankshaft.
All top end overhauls Ive seen on M113K All keep the cam sprockets connected to the chain and just sitting there suspended.
Old 04-07-2015, 08:43 PM
WANTED!!'s Avatar
Alrighty. Last question and I'll be getting on this fairly soon. What is the preferred valve compressor tool out there? I found the MB one and I'm not paying that by a long shot. The one I currently have is geared more towards DSMs and Evos, and perhaps a few other assorted imports.
Old 04-07-2015, 10:23 PM
bobgodd's Avatar
2004 E55
I replaced my seals and did it sort of the same and sort of differently.
I used a different tool, found on eBay, that looked just like this. It was adequate for both exhaust and intake valves and did not require the removal of anything extra aside from the rocker bridge. You will need to take the rocker bridge off obviously, but you do not need to remove the cams or supercharger, or affect the timing at all.
As the tool doesn't mount perfectly to the engine, I had to go to a hardware store and purchase some longer bolts of the same thread and pitch as the rocker bridge bolts, and some washers to stand the tool off of the head a bit so it did not gnash anything. After that it was fine and just a matter of playing with different hole configurations to get the right angle on the valve. I used small hose clamps on either end of the middle pole on the tool to keep it from sliding free.
My valve retainers were stuck on pretty good so I put a large socket over them and gave it a few good taps with a hammer to loosen everything up, otherwise the valve and spring just kept depressing all the way into the cylinder. I also used the rope method, removed one spark plug and threaded a nylon rope into the cylinder, then rotated the engine until I could feel it go no further. This was more than sufficient for keeping the valve from dropping.
The rocker bridge bolts are torque-to-yield so they should all be replaced. If you use the tool above and do not remove the cams, there will be no need to adjust any timing or anything other than reinstalling whatever you removed.
Should also add:
1. If you use the rope, put as much in there as you can. I threaded in somewhere around 8 feet I believe. Also slightly depress the valve when removing the rope to avoid risk of the valve catching the rope and making your life more difficult than it needs to be.
2. I had to tap my retainers to break them from the seals.... But I had to tap it with a deep well socket and a mini-sledge. There might be an easier way to break it loose, but I didn't know of one lol.
3. Do a leak-down test first to make sure you're losing oil, then also to tell you where you're losing it.
Old 04-08-2015, 06:55 PM
WANTED!!'s Avatar
That's what I was wanting to know. Thank you. I was questioning if mine would work, but as you can see here that is the one I already have.
Thanks for reminding me about the rocker bridge bolts. I had completely forgotten to order a set of them despite having ordered every other gasket and bolt out there. Hell, I even have a set of head bolts and head gaskets should I actually have to take the head off for some unforeseen reason.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: HOW TO: Valve Seal Replacement
