Question about "-10 mod" and difference between Code3 H/E v Eurocharged H/E ...
Old Feb 10, 2010 | 10:53 AM
TQADDICT's Avatar
05 E55 AMG
Just as the subject title states, what is the -10 mod? What use is it? Is it a termostat? Any performance gains?
My second question has to do with the Code3 heat exchanger and the Eurocharged heat exchanger...what's the difference? Or are they basically similar in performance gains/efficiency?
Thanks for the clarification.
Old Feb 10, 2010 | 10:58 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
M3ADDICT = TQADDICT??????
Old Feb 10, 2010 | 11:03 AM
grantwoodtx's Avatar
GLE 63S
Wink
Very POSSIBLE!
Old Feb 10, 2010 | 11:05 AM
TQADDICT's Avatar
05 E55 AMG
Wait, what?
Old Feb 10, 2010 | 11:14 AM
LYE55's Avatar
WTB: 06 E55 AMG
From what I've read on here and people I've spoken to, the -10 is a fan modification (changing the temp range, i.e. cooling quicker than usual) and isn't really necessary unless you get into heavy modding (i.e. more than just a pulley/tune upgrade). That's what I've gathered so far with my own research on here and also talking to various MB gurus around town.
As far as the heat exchanger, I don't think you can go wrong with either. Most folks on here seem to go with Code3 and others have the Euro one. Either way, both are reputable and you can't go wrong with either product.
Good luck
Old Feb 10, 2010 | 11:19 AM
320 dreamer's Avatar
2003 porsche 996 turbo
the -10 fan mod is a star diagnostics change in the temp range that the fan kicks on at. an example would be normally the fan comes on at 195* F. the mod will tell the fan to kick on 185* F instead cooling the fluid sooner. this can be done all the way down to approx 155* F but cel may be triggered by the p0128 (low coolant temp) code. the mod usually runs about 50$
this mod varies from area to area depending on your specific needs ie: fl and arizona can be set lower than colorado and montana.
as for the h/e the only way to know is to ask each manufacturer what the h/e is made of how big are the cooling tubes and how many sq inches of cooling space each has. then compare prices and go from there
i dont know how much space you have in the front of your radiator but this is what i have in my slk32. its huge and cools like a beast! cost was 350$
Old Feb 10, 2010 | 12:36 PM
Mikesamg's Avatar
A Prius because I'm green
I mentioned this in the thread about quality where Eddie500 and M3Addict go out it on E55s. I noticed it because of the names but also TQaddict started his account and posting right around the same time your buddy M3 came back. Suspicious is all I am going to say. I couldn't give M3 enough credit to be smart enough to come up with a less than similar name so who knows but I have all the faith in you fishing him out
Old Feb 10, 2010 | 12:49 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Code 3 is a bar and plate design (suited for air)
Eurocharged is a tube and fin design (suited for liquid)
Old Feb 10, 2010 | 01:59 PM
azncantonw211's Avatar
2005 E55 & 2007 335iC
I believe m3-addict disguises himself as other usernames so he cant ask question he doesn't know. Then when he has the chance to "shine" his knowledge of the AMG's he can sound intelligent.
Old Feb 10, 2010 | 02:11 PM
TQADDICT's Avatar
05 E55 AMG
I have no clue what the hell any of you are talking about. I have zero clue who the other member is or what he has done.
I just purchased my 05 and joined the forum recently to gain insight on some things (maint, mods etc.) for the future.
If you guys are just going to waste my time and not answer questions, maybe it's time I look for another forum.
emoving,
You have nothing else better to do than accuse someone of this simply because they joined around the same date and have a similar username? If so, you must have some exciting life ...
Old Feb 10, 2010 | 02:13 PM
TQADDICT's Avatar
05 E55 AMG
Are either better than the other in any way?
As far as cooling efficiency or any other difference?
Old Feb 10, 2010 | 02:17 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Trunk pic now?
Old Feb 10, 2010 | 05:41 PM
Worth the wait's Avatar
2006 E55
You guys need to get out....Sheez!
Old Feb 10, 2010 | 06:57 PM
lauer87's Avatar
E550
IP check??
Old Feb 10, 2010 | 07:24 PM
LYE55's Avatar
WTB: 06 E55 AMG
Originally Posted by lauer87
IP check??
I just did an IP check on TQADDICT... says location is in Northern Maryland.....
Not sure where the other member is ..?
Old Feb 10, 2010 | 07:54 PM
all anyone needs to know about fan mods compliments of the guys at eurocharged!!
https://mbworld.org/forums/c32-amg-c...r-das-how.html
