Quaife LSD install: did u guys buy new bearings? (part numbers?)
Old Jun 8, 2010 | 05:01 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
i want to have my quaife lsd installed and i was wondering if anyone knows the part numbers for the bearings inside the diff. i looked through the install thread in the DIY thread but i wasnt able to find any part numbers. i do have the part number for the seals though. (A2309970346)
for those of you that have already done this, did u buy new bearings or reuse the ones in your oem diff? i would prefer to get new ones and i believe thats what Brian S. mentioned in his DIY thread as well.
i was given this part number from the shop that told me to reuse it but im not sure if it is correct, because when i had it looked up it came up as an S class part: Universals & rear axle - Drive axles - Differential - Side bearings Side bearings, s500, s600, s55 2000 - 2006 . (A0029801702)
anyways, i called a couple of the dealers in my area and spoke with the parts dept and i was told that i can only buy the diff as one whole unit. they didnt even have a breakdown of the parts inside it.
if anyone has part numbers or feedback on reusing the bearings in their oem diff then please let me know.
thanks!
Old Jun 8, 2010 | 05:14 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
You can use new bearings which is probably better but I didn't. The diff I used had 5000 miles on it so figured the bearings would not need replacing after that milage. Also it was a donor diff ... if it breaks I just put my oem one back....
I did put in new seals and had the diff installed by Quaife themselves who inspected the diff before the install to check tolerances etc and all was hunky dory ... app they do this on every diff they modify for thier warranty purposes.
Sorry dont have the bearing part numbers...
Old Jun 8, 2010 | 05:16 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
In Bruce Willis voice from Diehard.
Welcome to the party pal!!!
Yup, Benz won't sell parts to the diff. Just the whole pumpkin.
No new bearings here and thousands of miles later, no trouble.
Old Jun 8, 2010 | 05:26 PM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
thanks!
The part numbers that I gave you are 100% correct. They are tapered bearing for the differential and are used on many MB diffs. List $64 and you need 2.
If you need anymore help with the Quaife install just give me a call!
Old Jun 8, 2010 | 05:28 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
i just called the parts dept in seattle, wa and i was told that the part number for the bearing that i listed above fits about 78 different mercedes cars. unfortunately he doesnt see the cls on the list (219) but he does see the E class there (211). arent they using the same diff? he said that this is used in the diff of the e55.
my car is already approaching 60,000 miles (93,000 kms) so it might be better to throw in new ones.
thanks bruce! ill try to find somewhere to order them!
Old Jun 8, 2010 | 05:34 PM
Call any MB dealer and they can order them for you. Parts.com has them for $42.55 each. My MB dealer matches Parts.com pricing for me and I don't have to pay shipping!
As Mel Brooks says......."IT'S GOOD TO BE THE KING!"
Old Jun 8, 2010 | 08:49 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Terrance here are the part numbers you need to order:
230 350 03 49 and 230 350 02 49
Old Jun 9, 2010 | 03:40 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
thanks james.
hmm there are so many different part numbers now.
i guess all of these different ones work?
Old Jun 21, 2010 | 11:32 AM
xpl0sive's Avatar
CLS55 AMG
these are the part numbers that I have too.
A230 350 03 49 and A230 350 02 49
Can anyone confirm the part numbers for the seals?
also, does anyone have the part number for the new Hub Nut? i was told to replace that as well
Old Jun 23, 2010 | 11:57 AM
money-one's Avatar
C43/2jz, Ml63, C32
Why 2 part numbers? Are they different left to right?
Old Jun 23, 2010 | 12:58 PM
James@ACG's Avatar
yes, one is thicker then the other by a few mm's
Old Sep 7, 2010 | 12:28 PM
box986's Avatar
W211 E63
Can someone confirm we have A230 350 03 49 and A230 350 02 49 for the bearings and A230 997 03 46 for the seal? Going to get mine install soon. thanks
Old Sep 8, 2010 | 12:40 PM
James@ACG's Avatar
Yes those are the part numbers that we have been using. We also have them in stock.
Old Sep 8, 2010 | 09:17 PM
box986's Avatar
W211 E63
Thank you James for sharing the information, would I need 2 of the A230 997 03 46?
Unselfish Sponser like you make a car forum a worthwhile place to spend my time on everytime I come online.
Old Oct 1, 2013 | 11:22 PM
MAN55LE's Avatar
04 E55 AMG
And it lives! back from the DEAD
https://mbworld.org/forums/w211-amg/...e-install.html
Old Oct 2, 2013 | 11:44 AM
MAN55LE's Avatar
04 E55 AMG
ttt
Old Oct 2, 2013 | 07:24 PM
green1212's Avatar
2004 MERC E55
bearings
you will need the part number as listed above the thread. same part numbers: 230 350 03 49 and 230 350 02 49. these are the bearings for the left and right side of the diff. when you take yours out you will see that one side is indeed thicker just by a very small "smidgen" than the other (right) side. good luck and should be easy install. hardest part maybe those giant circlips!!! damn pita getting those out and putting them back in. take care.
Old Oct 2, 2013 | 07:42 PM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
not a pita if you have the right tools for those giant circlips, I have a large knipex internal circlip retaining ring plier, that was a breeze for me.
And yes those are the right part #'s for the bearings.
Old Oct 2, 2013 | 08:49 PM
MAN55LE's Avatar
04 E55 AMG
