Grille painting question...
Old Jun 25, 2010 | 09:52 AM
pullejo's Avatar
'12 E63, E55(sold), C32 (sold), '65 Skylark GS 445 convertible, '12 ML350
I'm debating on getting a black 3 fin grille...or just blacking out my stock grille.
For those of you that have blacked out your grille, what paint did you use? Flat black? Semi?
Since I don't have an flat black on the car at all...I'm thinking a semi or high gloss might actually be better.
Just ordered a diffuser, front lip, and tail spoiler yesterday as well.
Next stop, 19"'s and new rubber.
Old Jun 25, 2010 | 10:02 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
from what i have seen in the past painted grills look good, but be prepared to paint it every 6 months becasue you will get rock chips.
Old Jun 25, 2010 | 10:05 AM
pullejo's Avatar
Yep - I've already thought about that. I'd blacked out a grille on an S70 T-5 I had a long time ago...with several coats on it, it was rare that a chip went down to the chrome.
Old Jun 25, 2010 | 10:10 AM
shardul's Avatar
have you tried pastidip?
Old Jun 25, 2010 | 10:34 AM
novae500's Avatar
W211
i dropped of mine at a local bodyshop. $80 later next day got it painted black and clear coated.
Old Jun 25, 2010 | 10:45 AM
pullejo's Avatar
I've never used Plastidip.
I did just finish murdering my V-Rod (which turned out great) by myself...
...so I'm not scared of painting myself.
novae500 - did they use a flat black prior to the clear or semi or high gloss? Looks great.
Old Jun 25, 2010 | 01:04 PM
Infiniti's Avatar
a unicorn tuned p30 e63
I used semi flat black and sanded down the chrome until it was almost all off, i then used some primer and sprayed it semi flat black and it came out great. it kinda matches the mesh in the front bumper, and you will have to respray it every couple of months but most people think i had it done rather than myself.
Old Jun 25, 2010 | 01:08 PM
CSanders's Avatar
2006 E55 AMG
I did about 10 coats of Krylon Fusion flat and have had no chips. With the Krylon I didn't have to sand or prime.
Old Jun 25, 2010 | 01:13 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
You could paint it then wrap it clear. That would eliminate most rock chipping.
Old Jun 25, 2010 | 01:43 PM
novae500's Avatar
W211
It was semi gloss and hit with a couple coats of clear.
Old Jun 25, 2010 | 01:58 PM
jayhawkblk's Avatar
2012 Armada
I sanded and primed mine then painted flat black but have chips already. i am thinking of using some rhino liner type stuff. I will just thin it out so it is not textured and does not clog up my gun. But going to a gunmetal this time and painting the mesh the same color.
Old Jun 25, 2010 | 03:14 PM
AreL11's Avatar
2006 E55 AMG
Vinyl wrap it.
Old Jun 28, 2010 | 08:31 AM
pullejo's Avatar
I thought about vinyl wrapping it...but I'm thinking chipping would be more of an issue to deal with than painting. (a paint chip is easily fixed with a shot of paint...)
Old Jun 28, 2010 | 09:14 PM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
Get it done at a shop professionally for $60-$80 and call it a day. The black gloss most people use is Mercedes paint code 040.
Old Jun 28, 2010 | 09:28 PM
Karlson's Avatar
06 E55
I wish it was 6 months, have to repaint mine every 3-4 months!
Old Jun 29, 2010 | 12:41 AM
mchapparone's Avatar
Huracan. S63. CL63. E55.
20,000 miles after painting mine at my body shop and not one chip...never had to repaint it once
Old Jun 29, 2010 | 01:56 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Awesome car
Old Jun 29, 2010 | 08:13 AM
pullejo's Avatar
mchapparone...you've got the EXACT look I'm going for with mine. Glad you responded.
My cf lip, diffuser, and tail spoiler arrive tomorrow. I'm in the process of hunting down wheels (I will not be painting my calipers though).
Love the look of your CAR!!!!!!!!!!
Old Jun 30, 2010 | 11:36 PM
jicl55's Avatar
2003 cl55 (sold)
And if you did have to repaint it, you wouldn't have to go very far! Saw your car at James at ACG one day a while back. Definitely looks sharp and love that color. You on Balboa? May need to get some touch ups to the bumper, etc.
Old Jul 1, 2010 | 01:07 AM
Thanks guys! Jordan, PM replied!
FYI guys it is very important that you don't paint the grille as one piece, wherever you get the work done make sure the shop detrims the grille and preps it properly.
At my shop we refuse to do it any other way. We charge more but it gets done right the first time. Rather than gradually spending a little bit over and over again!
Old Jul 1, 2010 | 01:22 AM
jagass's Avatar
pick up
If you want to save more money, it's much better if you will just paint the stock. it depends on you man.
Old Jul 1, 2010 | 03:28 AM
Luke_Geezy's Avatar
2009 blk/blk C63 AMG, 2010 wht/blk c300 sport, 06 c280, 12 Triumph Daytona 675R wht/blk/red
i just finished painting my grill flat black, and it came out absolutely perfect. you need to start with a 150-220 grit sandpaper, be patient with the 220 grit. work ur way all the way up to 600 grit so its perfectly smooth. after that use a tac cloth to remove all unwanted debris from sanding, then u are going put a few coats of primer. wet sand the primer after the first coat, then prime it again, let dry, spray gloss black ( few solid coats should do ) then clear coat and ur ready to go =] heres a pic of how mine turned out. i did it myself in my garage, it took a couple hours all together, can easily be done in 1 day.
Old Jul 1, 2010 | 05:57 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Oh man, love your car ! very nice done !
