Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Mercedes-Benz C-Class AMG: How to Replace Crank Shaft Position Sensor
Step by step instructions for do-it-yourself repairs
Crank Shaft Position Sensor DIY with PICS
#177
All of the torx screws that affix the air filter boxes to the engine bay. These screws are all the same sizes so you shouldn't run into any confusion. I would recommend replacing the engine air filters at the same time since they will be coming off regardless. I'll try to get pictures for you in a little bit.
#179
is this the correct one ? or is there a better quality merc/oem one ?
Amazon.com: Bosch 0261210170 Crank Position Sensor: Automotive
#183
I was trying for 35 minutes to get to it. I gave up for today. I thought my E320 is tight but on the E55 I can't even reach the end of the cable where the connector goes into the CPS. I don't even see the screw.
Do I have to go in from beneath?
#184
No you need to approach it from the top with the air box removed. First you should unplug the plug from the sensor -- this plug has a heat wrap around the top and is removed by pushing down on the ends. The sensor itself is seated at an angle and is bolted into place with a screw. You will need an E8 female head with around 10" - 12" of extension, as well as a 1/4 ratchet of course. Once you get the screw loose, remove it with your hand so that it does not get lost (it's really easy to drop). Then you need to place the new sensor in the spot where the old one was. This part is tricky because you have to place it by feeling around the area with your hands -- you won't be able to see anything. Once you believe it's in the correct area, place the screw back in and begin tightening it with your 10-12" extension and ratchet. Once that is done plug the plug back in and you should be good to go.
#185
I removed the filter box and went down the cable with my hand to feel where the screw is but I couldn't reach that far. And because of that I couldn't unplug it either. Now it's too dark ;(
#186
How did you guys take the Y-Pipe from the TB off? It's secured with a clamp with a little clip/lever on top. I didn't touch it since I never took it off on this engine.
#187
There is the thick wiring harness coming from the Engine compartment electrical box going down and splits. The smaller wiring harness is the one that goes to the CPS but I just can't reach the connector.
So how do I open the clamp? Maybe someone has a picture with a quick explanation?
#190
If you have removed the front air tubes, then both air boxes will pop off their rubber mounts (don't need to unscrew anything for this step). Then only the Y-pipe will be holding the whole assembly onto the TB. There is a clip on top and a hidden one underneath. When I did mine I just unclipped the top one then the bottom one came loose. It's a little tricky, so take a close look at how the clip works and you should be able to get it without using any tools. Then the whole Y-pipe and both airboxes come out as one big assembly.
#192
I tried again today. Epic fail. I just can't get to the connector and unplug it. I don't feel the screw either to place the socket on. I follow the wiring harness coming from the SAM box. It splits. The slit off cable I follow down and that's the end of it.
According to the pictures in post one the screw is at 6 o'clock underneath the connector of the sensor. This makes even less sense.
Who in his right mind positioned this sensor down there instead of on top of the tranny where it's easier to get to it once the air filter is off from the TB?
#193
This is on the top of the bellhousing, where it meets the block. I had to unbolt the sensor before I could unplug it.
#195
Yes you're in the right place. It's not too deep down, you should be able to find it. The head of the cable has a heat shrink around it. Keep at it -- best of luck.
#196
Does the heat shrink prevents me from seeing the screw and won't allow me to press in the little latch to get the connector off the sensor? Maybe that's the reason I can't really get to it with my hand. I'll try to get straight to the screw with my 18 inch extension.
#197
No it should be unplugged before you attempt to remove the screw with the extension. So try unplugging the cable first, and then feel around with your hand for the screw. You have to go through it using feel alone since it's too dark and cramped to see inside.
Also try positioning yourself behind the driver's fender as opposed to being in front of the car.
#199
