ASP 180mm belt??
ASP 180mm belt??
What belt do you guys use with the 180mm ASP pulley? I thought I got the right one, but apparently it's too long. Thank in advance!!
Thanks guys. My stupid belt was ok until higher rpm. It slips at higher rpm and broke. On its way out, it's also took a small coolant hose with it. I guess it could have been worse.
I'm currently running the gates 525 but the only reason is b/c I have those darn phenolic spacers under my blower plus a 180. I shredded the 514 (which barely fit)
I can agree with shardul, there is definitely something not right with the 525
I'm running the K080525 belt as I have a 172 and phenolic spacers, the 514 belt shreaded twice before we move to the 525 belt. The 525 has jumped the pulley a few times, not shreaded except for the one outer rib the rest of the belt is intact. Touch wood this one has been on for 4 weeks now. Jerry is getting me another belt to try just in case.
