Anyone buying a 55 plan on changing rims
Old Apr 20, 2003 | 12:25 AM
RJC's Avatar
RJC
Various
Exclamation Anyone buying a 55 plan on changing rims
If anyone is planning on up-grading to 19 or 20's please let me know as I am interested in the stock wheels/tires to up-grade my 209 500 17's.
Old Apr 21, 2003 | 09:20 PM
Blocktrader's Avatar
2003 E55,2005 Ferrari F430 Spider, 2005 Corvette 427 TT, 2005 Range Rover
I have the single spoke E55 wheels on my E500 with Potenza S-03's that I'll likely sell when I trade my car in. They have 4k miles. 245/40/18 Front. 275/35/18 rear.
Old Apr 21, 2003 | 09:35 PM
RJC's Avatar
RJC
Various
I'm looking for the stock split spoke 18's with tires, going from 17's on my clk 500 to split 18's should be good enough for me. I'm looking for someone that might want to change from the split 18's to the new split 2 piece 19's or another 19 or 20" brand. If you deicide to go for something more unique let me know as I'm in your area.
Old Apr 21, 2003 | 11:05 PM
pocholin's Avatar
Volvo V90 CC
Is the bolt pattern the same?
If you have 5 x 112 i'll sell you my Carlsson 1/5s ($900.00) 18 x 8 and 18 x 9
Old Apr 22, 2003 | 04:44 AM
pogotango's Avatar
e500
well, im going to change then if they can't provide me with amg 19" wheels, then im going with some lowenharts. soo yea ill keep you posted
Old Apr 22, 2003 | 10:51 AM
RJC's Avatar
RJC
Various
Thanks. Where are you located?
Old Apr 22, 2003 | 10:55 AM
Schiznick's Avatar
SL65, E55T, Pending S65
I am considering changing the split spoke 18"s to 19" when me E55 arrives next month. I am located in Atlanta. Will let you know when the car arrives. I have a friend that just ordered the 19's for his SL and I will try them on the E to see how they look.
Schiz
Old Apr 22, 2003 | 02:21 PM
pogotango's Avatar
e500
i live in cali, la.
Old Apr 22, 2003 | 02:23 PM
pocholin's Avatar
Volvo V90 CC
i live in cali, la.
la, Louisiana????
Old Apr 22, 2003 | 04:34 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Re: Anyone buying a 55 plan on changing rims
The W211 E55 rims will not fit the CLK. The offset may be a problem and they used 14mm lugbolts while the CLK uses 12mm bolts.
Old Apr 22, 2003 | 06:57 PM
RJC's Avatar
RJC
Various
I had a discussion with Luke @ Tire Rack about this today, he said he was waiting to see something about the center design of the wheel(hubcentric?) (offset?) and he did not seem too concerend about the 12mm vs 14mm. I did see a guy in the 209 section did the conversion, he posted details and pix. Please explain the details to me about your concern regarding the 12mm vs 14mm and offset.
Old Apr 23, 2003 | 04:23 PM
E55 KEV's Avatar
Veteran: Air Force
RJC, Since you are asking about used wheels you probably are looking for a very low cost upgrade. However, the Double Spoke Wheels for the CLK do come in 18X7.5 and 18X8.5 rear and are readily available from a few Internet vendors already.
In order to use 14mm Bolts you would have to modify/redrill the brake rotor hubs. Then the bolts for your Spare Tire will not fit either.
Checkout the Tire & Wheel section there are many post asking about using 14mm bolt wheels on cars with 12mm Bolts.
Old Apr 23, 2003 | 10:06 PM
RJC's Avatar
RJC
Various
[QUOTE]Originally posted by E55 KEV
[B]RJC, However, the Double Spoke Wheels for the CLK do come in 18X7.5 and 18X8.5 rear and are readily available from a few Internet vendors already.
Thanks Kev...please explain/give details, also will these wheels be a direct fit?
Old Apr 24, 2003 | 12:24 PM
E55 KEV's Avatar
Veteran: Air Force
[QUOTE]Originally posted by RJC
[B]
The Double Spoke rims for the CLK bolt on directly without any mods:
18X7.5 et37 225/40/18
18X8.5 et34 255/35/18 rear
Old Apr 24, 2003 | 07:45 PM
RJC's Avatar
RJC
Various
Thanks Kev...You mention these wheels are available on the net , would you please provide the info?
Old Apr 25, 2003 | 09:39 AM
E55 KEV's Avatar
Veteran: Air Force
They are pricey. Contact Ross at www.statusimports.com . Good Luck!
Old Apr 25, 2003 | 05:16 PM
RJC's Avatar
RJC
Various
Thank You
