Eurocharged/Jerry tuned my S55...
Old Oct 19, 2010 | 05:41 PM
Bramage's Avatar
F-250
369hp/483tq with pulley only
436hp/517tq after Jerrys tune
He had the pulley for the first pull, but it was not tuned, so the advantage of the extra boost would not be "As Noticable". That is why he got such great gains. Pulley and tune typicly provive 75 - 80HP and anywhere up to 100 trq
Old Oct 19, 2010 | 09:30 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Thanks for all the comments guys. Mental we need to link up sometime. I need to see that beast!
Rac3me, looking forward to it!
Bramage You make sence Metal, and please note: I want this bad..
I want all the torque, and so did AMG, but if there is a fail safe for when the planets align, and a peak condition occurs, I would like the limiter to assist. I think Jerry ups the limiter, vs. removing it.. That is my guess.
How do I get it?
Lets go.. Im as sick as they come.
LOL, we are all sick for power!
I know nothing is removed but about 10-15 parameters are adjusted to bring out a little more insanity! I like safety too and Jerry has that in his tune, even with the new changes.. The 65 V12 put a lot more torque to the tranny and rear diff than even my car can apply! Same tranny and same diff. So , we have more room to go..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 20, 2010 | 01:28 AM
ASP's Avatar
ASP
2016 Freightliner "daily driver"
After beating on my car around with the tcu mod for a day now, I feel a tremendous difference. First the car shifts way faster then it did before, the torque limiter is still there from what I felt but only on the top end???? which I'll check with Jerry if he can smooth it out somehow. My last dyno I layed down 525whp/565tq at the wheels so traction was always an issue but now I'll spin my tires 1-2-3 with traction on. I also felt a really big improvement when the trany downshifts, before it would hesitate and now it responds by downshifting instantly each and every time. I also have the high stall torque converter and before it wouldn't be very responsive when moving from a stop and now I feel that issue is almost gone.
