Help me understand Lsd in e55??
Old Oct 20, 2010 | 01:50 PM
LEX99FRC's Avatar
e46 m3
i see plenty of videos of stock e55 doing burnouts and its always 2 tire marks which would mean it does have lsd but from reading here people are saying it doesnt have an lsd
also plenty of vids of the car drifting in stock form wouldnt that be very hard-impossible to do if it had no lsd?
please someone educate me thanks
Old Oct 20, 2010 | 02:27 PM
izzyz28's Avatar
2004 E55 AMG
The car uses the brakes to slow down the wheel that is spinning, transferring the wasted power to the wheel with grip. However, it has a hard time transferring the power if both rear tires are on different surfaces, or if you stand on the gas and one tire immediately starts spinning while the other stays planted. It's not a true LSD, but it does work well for what it is.
Old Oct 20, 2010 | 02:50 PM
LEX99FRC's Avatar
e46 m3
but if one starts spinning and one is planted how do they leave marks from both wheels? also how do they drift
another question is the cls55 any different then e55?
Old Oct 20, 2010 | 02:56 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Both the CLS55 and E55 share the same components, engine, tranny and suspension. The E55 will lay down two burnout marks, if you put your foot into it. My E63 and C63 will do it without hasitation.
Old Oct 20, 2010 | 03:07 PM
LEX99FRC's Avatar
e46 m3
so then it will fishtail through a turn etc like an lsd car would?
Old Oct 20, 2010 | 05:00 PM
izzyz28's Avatar
2004 E55 AMG
If there is a large difference in traction you will feel one tire spin for a short time while the SBC unit figures out what's going on. 99% of the time both tires will spin, but you will definitely feel the 1% they don't, usually from a dead stop or a slow roll on cold tires. Again, this is only for fractions of a second to 1 or 2 seconds in extreme cases. Otherwise these cars act just like they have an LSD, and they will absolutely slide around and spin both tires in a turn.
Old Oct 21, 2010 | 01:11 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
when i installed mine, night and day diffrence, before if a hammer it from a stop it will turn me to on fo the sides even if i control it as much as i can, but after installing the LSD. it doesnt flip to a side but goes on and the launch is much better.
if your car is heavly tuned you need it.
Old Oct 21, 2010 | 02:54 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
i finally felt it -- when the street was wet -- my car started to fishtail all over the place and I was only going in a straight line --- under dry conditions I can not feel it or see evidence of it = twin burnouts
