E63 service. 20k mile service is $500
Old Nov 14, 2010 | 10:45 AM
Vanditz's Avatar
2014 BMW M5 CP
Do you guys get the full service MB does every 10k miles? Input 20k mikes a year on this car. It is going to get expensive! They also recommend tire balancing every 10k miles. Thoughts? I went ahead and got it. Can't hurt anything except my pocketbook.
Old Nov 14, 2010 | 12:02 PM
W109 W211 6.2L's Avatar
2008 W463 G500, 2003 Terminator Cobra (710RWHP), 2012 S350 Bluetec, 2010 911 C4S, 2007 VRSCDX
Yep service D also includes a brake flush. I think it's fair considering the level of car it is. Also it does take 10 quarts of synthetic
Old Nov 14, 2010 | 12:26 PM
gonzales25's Avatar
Slow
My last service (40,000 miles) I got a tranny flush and a brake flush,,,,ouch $$$$
Old Nov 15, 2010 | 08:39 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
I now have 63k on my 2007 E63
I read my manual and change things based on that
20K should be an easy service, just change the oil. Of course the dealer will charge you for checking everything is ok with the car (service items 12 and 14 in my manual).
If it gets to be 2 years, change the brake fluid
40k change the tranny oil (it says once but not me, every 40k is my plan - this is also the only thing I do not do myself)
30k or 2yrs, the AC combination filter
40k or 4yrs, the enginer air filter (I do mine more)
60k or 5yrs, spark plugs (see my DIY)
150k or 15yrs (really?) change the coolant and fuel filter
3yrs clean and lube the pano roof (this is still on my list to complete)
I guess I would change the steering fluid after 150k.
I will also change the diff oil again at about 80k (I have the LSD)
As used:
Brake Pads (fronts done at 62k, although many on this forum use them faster)
Rotors (have not heard of anyone going below minimum thickness)
Tires - rear for me are 12-13k, but some on the forum get half this. Fronts, 2x, so for your comment on re-balancing I would rebalance the fronts when I get new rears.
Old Nov 16, 2010 | 01:02 AM
Vanditz's Avatar
2014 BMW M5 CP
damn. I paid 600 for the 20k mile service. Not sure everything they did. I just brought it to the dealership for the service.
Old Nov 16, 2010 | 08:34 AM
lawguy's Avatar
Formerly: 2007 e63; 2012 GL450
Is that Service "G" ?
Old Nov 16, 2010 | 12:12 PM
So here are the things they are charging you for. Personally, I do enough of this myself I can not see paying for it. If you go in and say Service A/B/C/D/E/F/G, etc, you will get charged big. We know service A is just an oil change. But beyond that, if you do not read your manual you have NO idea what the other service levels MAY require.
US Service 13 - first at 10,000 miles or 1 year; after first every 20,000 miles or 2 years
Engine compartment
Check catch, safety catch and hinges on engine hood for proper operation 8851
Check the following fluid levels, correct if necessary.
If there is a loss of fluid, determine cause and perform repair with separate work order
Brake system 4210
Power steering 4611
Windshield washer system (incl. summer/winter cleanser) 8210
Interior
Reset maintenance service indicator in instrument cluster 0042
Function check
Warning/indicator lamps, illumination and interior lighting - - - -
Windshield wipers, windshield washer system, headlamp cleaning system, where applicable: rear window wiper, rear window washer system 8252
Wheels, brakes
Inspect tires for damage and splits, measure tread depth and record in mm 4051
Check condition/thickness of front brake pads/discs (remove 1 front wheel) 4251
Correct tire inflation pressure - - - -
Trunk
Check battery condition using “Midtronics MCR 717” tester 5453
Check trunk lighting - - - -
Check TIREFIT sealant expiration date (wagons with third row seat only) 4045
Vehicle front/rear
Check wiper blade condition 8253
US Service 14 - first at 20,000 miles or 2 years; after first every 20,000 miles or 2 years
Engine compartment
Leakage - Major components
Check for chafe marks, line routing, damaged components
In the event of leakage, determine cause and perform repair via separate work order 0053
Check condition of poly-V-belt 1351
Check catch and safety catch and hinges on engine hood for proper operation 8851
Brake system 4210
Power steering 4611
Wheels, brakes
Check condition/thickness of brake pads/discs front/rear 4251
Remove and install wheels 4250
Interior
Function check
Check parking brake (function test only) 4290
Warning and indicator lamps, illumination and interior lighting - - - -
Check seat belts and buckles for signs of external damage and proper function 9150
Underside of vehicle
Check front axle ball joints for play, check rubber boots 3353
Inspect condition of driveshaft flexible discs 4152
Inspect play of tie rod and drag link joints, inspect rubber boots 4653
Trunk
Vehicle front/rear
Check, correct headlamp setting - - - -
Old Nov 16, 2010 | 12:14 PM
Absolutely no way to know unless you have your service record. According to your manual, Service G just means 7hrs of labor. There are no specific items associated with those 7 hours.
Old Nov 16, 2010 | 01:56 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
imho, forget this B/C/D/F/G stuff. That's really an internal shop thing that determines labor hours, etc..
I do what Jon is pointing out. Service based on mileage as stated in the maintenance manual. Go by the mileage on the odo and the time, and do the necessary service items.
My SA is way cool and printed out the service details based on mileage (and time) for me. Then when I bring in the car, he goes over the items with me and gives me the projected cost in materials an labor (and any discounts the dealer is running at the time.) None of the ABCXYZ stuff.
If you don't have the maintenance manual you can download them from the MBUSA website.
Old Nov 16, 2010 | 03:33 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
Park Place only lists Service A and B in their Flex Service anyways. My SA just lets me know when certain stuff should be done, or I gauge it on how hard I've been driving. I usually service earlier than recommended...
Old Nov 16, 2010 | 05:20 PM
NCE500's Avatar
2007 E63, 2006 C55
RE: Service Quote
I'd ask for a breakdown of what the $500 entails. If it includes brake flush, air filters, cabin filter, wiper blades etc. it is probably reasonable.
Old Nov 17, 2010 | 10:29 AM
Vanditz's Avatar
2014 BMW M5 CP
Citylight- it was service B at Park Place. Thy also did a tire balance for $50 and I paid extra for an interior detail ($70). Bill was $740.
Old Nov 17, 2010 | 03:11 PM
So what did they do besides
1. Change oil and filter
2. Tire balance
3. Interior Detail
Old Nov 18, 2010 | 12:36 AM
220S's Avatar
Just pick up my car this evening from doing the 20k or B service. Bill was $681.38.
They did the oil change plus O-ring, and new filter. Also new cabin dust filter.
And all the items listed in the maintenance manual (and Jon's post above), plus something called "cleaning out cowl and roof drains." And "lubed weather strips."
In addition, that price also included a "vehicle brake system flush" and brake fluid change which I requested (at 20k plus the car's build date is close to 2 years now; in-service date is 1.5 years.)
They also captured some oil from the middle of the drain stream which I'll be sending out for analysis. Last analysis was excellent. I changed out the original factory fill break-in oil at 1.5k. Have done another change since, plus one at the 10k service.
Car runs like a champ. Doesn't use any oil at all and no noisy tappets either. Knock on wood......
Old Nov 18, 2010 | 11:59 AM
Interesting. I bet the pano has a number of them. And those at the lower left and right of the windshield tend to be magnets for debrise. Of course most on this forum are far more meticulous about their cars and it is likely much less of a problem.
