Remove the coin drawer next to the glove box?
I use the slide out drawer next to the glove box for spare change and somehow got a coin lodged down behind the drawer. It is now making the drawer stick.
Is there an easy way to remove that drawer? I looked for a disconnect clip or button under the drawer and in the glove box...no luck. Thanks in advance for the help! |
I think I just pulled mine out after removing the glovebox etc etc, I do remember it goes right back in there with a slight push though.
I drilled a hole in the back of mine and run my iPhone through an aux wire to the glovebox. It's the shizzle, fits perfect and all ;). |
I drilled a hole on the inside of the glove box in the upper left corner just big enough to fit a monster 3.5mm cable through. I then ran in underneath the side of the center console carpet, underneath the gear shifter, and into the center console from the bottom up.
This appears to be one of the most asked question on these forums.
Take your pick: https://mbworld.org/forums/tags/drawer.html |
