Stripped my tensioner pulley bolt
Hey guys I found out today that my tensioner pulley bolt was loose so I decided to tighten it. I tightened it so much that the tork bolt got stripped. Any one know how I can remove the bolt because I will be changing out my tensioner tomorrow. Should I remove the tensioner and then clamp it then twist to get the bolt out? THanks for the help.
So Is the head stripped or the bolt in the engine?
Originally Posted by keith954
(Post 4746657)
If the head of the bolt is stripped try something like this: http://www.sears.com/shc/s/p_10153_1...u=00952157000P
They make several tools for inverted torx removal it looks like a small easy out
that sucks
Thx for the info guys!
Can you get a dremel in there and notch a slit in the head? You can make it so you can use a flat head screwdriver :nix: I've done it on other things :y I've always used a hacksaw but I doubt you could get it in there
Hey shardul i think it wasnt your tensioner it was the pulley that got loose. My bad
they sell a stripped bolt remover sockets, get a set from sears or something and tap one that fits on with a hammer. that ought to do it.
(Post 4746817)
same thing happened to me and thats exactly what I did with the dremel to get it out. :y |
Originally Posted by shardul
(Post 4746759)
that sucks
Update?
Same problem...
Its my Idler pulleys T-45 bolt thats stripped. Tried grip pliers (head is rounded and smooth, no grip), the sears sockets didnt work and neither did any of the other non welding related suggestions. Am I just screwed and need to take it to the dealer, or does anyone have any other suggestions? Im really starting to despise my charger. These things arent "durable" at all. Who in the hell puts plastic pullys on a car?! smh:nix:
pm sent
Originally Posted by Johncy2000
(Post 4746626)
Originally Posted by Exotic-metal55
(Post 5963647)
I have all kinds of engine parts, brackets and ton of bolts, so if you are in a bind, let me know and it is yours for free. Pm me.
EXOTIC - Do you happen to have a center bolt for the supercharger clutch laying around? 03' SL55 with UDP clutch but I stripped my center bolt pretty good trying to torque it down with a 24mm socket instead of a 15/16. |
Originally Posted by Tytiana1
(Post 5962743)
(Post 4746626)
One other thing is use a punch to start the drill hole. You want it to be exactly in the center of the bolt.
