What is the final word on paddle shifters on the E55?
Ive searched the forum looking for threads on converting the E55's shift buttons to the E63 style paddle shifters but see a bunch of different answers. I see many people manually switching them out and changing the computer chip, etc. Is there a direct and easy swap for a 2006 E55?
Originally Posted by CityOfAngels
(Post 4896058)
edit lol
Intrested in doing this aswell.. |
1 Attachment(s)
Originally Posted by tbal
(Post 4896088)
2011: Infiniti g37 Sedan
with 328hp, its luxury that thrills. 2003: Mercedes E55 Sedan with 493hp, its luxury that makes your pants wet just bit drunk yes. Use the DIY thread, its the best way to change to E63 paddles. I have also seen Carbon shifters ........... |
Definitely check out the DIY thread. That's what I used in doing my mod.
The modification does involve some dremeling/machining of the e63 aluminum paddle and plastic retainer, as well as cutting down the size of the circuit board which you mine from your existing buttons on your steering wheel. From what I understand, the e63 switch will not work in most cases, so you need to re-use your e55 switch. It's a bit of work and involves some tweaking and cutting, but if you are attentive and careful with your work, it will turn out nicely. Several hours worth of work if you're unfamiliar with what needs to be done. |
Several DIY on the mod, easy to do, time consuming is all.
linky?
I have some friends who are manufacturing a set of direct replacement paddles for the E55. So no retrofitting. They've already prototyped a set on my steering wheel, and they're moving to production soon
Check out onrailsengineering.com |
This probably makes more sense than what the PO did to get paddles on my car, install the (insert insane price here) Brabus steering wheel.
Not that I'm complaining! |
I wouldn't mind a stick-on solution. A good epoxy would be nice. I'm not really looking to tear apart my steering wheel
E55
Originally Posted by 55fanatic
(Post 6565642)
do let us know when they come out! I do not feel like disassembling the steering wheel just to add bigger paddles.
Originally Posted by CLK_350_Coupe
(Post 6565608)
linky?
A nice solution using the AMG paddles has been popular from DCT motorsports for more than 3 years now. 2003 and 2004 E55's become plug and play using the "Paddle Converter Module". The module is available from DCTmotorsports as part of wheel upgrades or can be purchased on its own. In Europe, ComandonlineUK stocks this module ... OR, you can get it directly from me (I am the manufacturer). 2005 and later E55s are already electronically compatible with the AMG paddles (and therefore do NOT need the "Paddle Converter Module") For those wanting to do this on there own, I can supply some useful instructions for modifying the E55 wheel for paddles (I have converted more 100 E55 wheels to paddles over the last 3 years and have created some instructions with annotated pictures) . I also have a laser-cut template that I supply with the paddle converter module (that I can send out separately as well). Cheers, Chris |
Why would anyone want to do this? They are very unresponsive and don't shift exactly when you actually engage them.
Originally Posted by TheOtherDodge
(Post 6566176)
While it could be argued that adding paddles will not likely improve your ET .... It can never be said that (unlike some other mods) it will require you make any compromises to your Mercedes in terms of ride quality and comfort. For myself, I started (7 years ago) with an AMG that had no paddle option (SLK32), and even if I had not come from a racing background (10 years racing in NASCAR and then other forms of racing as well), I'm sure I would have been dis-satisfied with just the touchshift. So I created a kit for the R170 and Chrysler crossfires to add a factory-like paddle implementation. Was it for everybody ? no ..... are a lot of people enjoying the kit ? (hell)yes. Then 4 years ago, I created the paddle converter module to solve this issue of making paddles plug and play on early 2003 through 2004 e55s (and 2003-2006 SL, S, CLK, CL 55s) .... Is this upgrade for everybody? no ... Is it for anybody who likes to shift and wants to bring their early AMG up to a newer spec ? yes Do I have paddles on all of my daily drivers? Yes (well almost all, I don't have them on my 7.3L powerstroke F250 ... that WOULD be silly : ) I hope I answered your question. Cheers, Chris |
E 55 works like a charm
Originally Posted by latemodel21
(Post 6566518)
I'll presume your question is NOT rhetorical and you are actually curious. While those who view their Mercedes as a quarter-mile car may have little need for shifting gears manually (yes, the car will never shift "exactly" when you bump the touchshift or use a paddle) ... for every other form of spirited driving, shifting is more convenient with paddles ... For downshifting on corner entry and just keeping it in the right gear in the hills what other choice to you have (other than shifting?) I would think that if you used manual mode on your e55 you would get to like the paddles. ... and you would likely find that the car shifts (downshifts in particular) close enough to instantly after you push the paddle.
While it could be argued that adding paddles will not likely improve your ET .... It can never be said that (unlike some other mods) it will require you make any compromises to your Mercedes in terms of ride quality and comfort. For myself, I started (7 years ago) with an AMG that had no paddle option (SLK32), and even if I had not come from a racing background (10 years racing in NASCAR and then other forms of racing as well), I'm sure I would have been dis-satisfied with just the touchshift. So I created a kit for the R170 and Chrysler crossfires to add a factory-like paddle implementation. Was it for everybody ? no ..... are a lot of people enjoying the kit ? (hell)yes. Then 4 years ago, I created the paddle converter module to solve this issue of making paddles plug and play on early 2003 through 2004 e55s (and 2003-2006 SL, S, CLK, CL 55s) .... Is this upgrade for everybody? no ... Is it for anybody who likes to shift and wants to bring their early AMG up to a newer spec ? yes Do I have paddles on all of my daily drivers? Yes (well almost all, I don't have them on my 7.3L powerstroke F250 ... that WOULD be silly : ) I hope I answered your question. Cheers, Chris 3 modes, Cruise, Sport & Manual, and here this is where it comes in handy very very much indeed, as for ex going downhill I dont want burn my brakes flip the switch 1 gear lower and or engage cruise control is actually much better I have to admit, futhermore the buttons just sucks are small and hard to hit lol paddles diffently is better. Now as my friend said :y |
(Post 6566629)
I got to answer on this one to being a E 55 AMG V8 Supercharged driver, im not sure if you have the 5G Gearbox but we have
3 modes, Cruise, Sport & Manual, and here this is where it comes in handy very very much indeed, as for ex going downhill I dont want burn my brakes flip the switch 1 gear lower and or engage cruise control is actually much better I have to admit, futhermore the buttons just sucks are small and hard to hit lol paddles diffently is better. Now as my friend said :y "im not sure if you have the 5G Gearbox but we have 3 modes, Cruise, Sport & Manual ... " One of my daily drivers is a 2003 SL55; it has the same 3 modes. And, with an upgraded 2004 valvebody in the transmission and 2004 TCU it behaves very much like yours. One of my other DDs, the SLK32 has essentially the same transmission (only 2 modes however ... one being "manual" by virtue of a tuned TCU). The Paddle Converter Module will make the AMG paddles plug and play in your 2004 E55. PM your email address to me if you would like me to send you some more information about it. Cheers, Chris |
Guys, he did my DCT wheel and it turned out Great. Very good work and it's night and day over the buttons.. :bow:
latemodel: Be assured I was not being sarcastic or rude and sincerely apologize if I appeared that way. I really was wondering because I feel the shifting performance of these cars is horrible, either in a straight line, down windy roads in any mode.
(Post 6567163)
Its all good bud :y Cheers, Chris P.S. SilverStrk thanks for the kind words .... it was good working with you. |
Cheers! Yes, upshifts are horrible and I equate it to much like a clutch car (of the 70's). If there is a solution, please let me know. I got the Eurocharged TCM programming but didn't really see a difference.
Originally Posted by Elhonaz
(Post 6565893)
Please let us know when this happens! Any pics of your setup?
Ams 5 months later
(Post 6565893)
I have a set of 63 paddles I never put on my 55 before being totaled. New in the box paid about $110 or so. Sell for $75 shipped.
