ACG Proud to Announce Brake Packages!
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
ACG W211 E63 Stage 1 Street Brake Package: $1,050.00 Shipped
- Endless MX72 Front and Rear Street/Track Brake Pads
- ACG Complete Stainless Steel Brake Line Kit
- Motul RBF 600 Racing Brake Fluid (2 500ML Containers)
ACG W211 E63 Stage 1 Race Brake Package: $1,200.00 Shipped
- Endless ME20 Front and Rear Track Brake Pads
- Motul RBF 660 Racing Brake Fluid (2 500ML Containers)
ACG W211 E63 Stage 2 Street Brake Package: $2,950.00 Shipped
- 360x36mm Front 2pc Slotted Racing Rotors
- 330x26mm Rear 2pc Slotted Racing Rotors
ACG W211 E63 Stage 2 Race Brake Package: $3,150 shipped
- 360x36 Front 2pc Slotted Racing Rotors
- 330x26 Rear 2pc Slotted Racing Rotors
ACG W211 E55 Stage 2 Street Brake Package: $2,550.00 Shipped
- Akebono Front and Rear Street/Track Brake Pads
- Goodridge Complete Stainless Steel Brake Line Kit
Our 2 piece rotors are a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The rear rotors are approx 5-6lbs lighter per rotor then the stock units. 23.5lbs vs. 35.5lbs. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the ACG Brake system is in place, simply replace the cast iron rotor when needed for only $350 per corner.
When used with performance pads and hi-temp fluid, you have what amounts to a truly amazing solution to overheating or warping rotors.
All items can be purchased separately, Ti Shim's are also available.
Rotors alone are $2100.00 but will be discounted to $2,000 for the remainder of the month.
James@ACG
James@ACG
Thanks Tal, I've been working on these packages for a few months now and we are finally stocked and ready to go, just need to assemble the hats to the friction rings.
'06 E55
I stopped b there once before and met Peter. The cars you had in the shop made me feel like I was driving a '97 Camry. I may stop by and show off my new exhaust setup.
I definitively recommend ACG, this is where I got all my non-warrantied work done, they are very diligent, professional and overall nice guys. Funny thing is that I ask James a quote on rotors and pads just last week! Now I have to find 3G!
