Can't get my 04 E55 AMG into dyno mode
Old Apr 2, 2012 | 04:33 PM
nizzle's Avatar
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
I have read the how to on this site, I have watched the youtube video as well, and I cant seem to get it right. I put the key in, turn to position 1, hit reset 3 times before SRS light flashes and....... nothing. No voltage screen, scrolled thru the menus.... No dyno mode screen.
Also, tried the youtube way.... Turn key to run position (so all lights and chimes come on), turn all the way back off, turn to position 1, hit reset 3 times before SRS flash and still..... Nothing.
Any advise?
Old Apr 2, 2012 | 04:47 PM
Hulk's Avatar
A Merc
It should show voltage and then scroll up or down and you will see dyno then press the + button and shut off and turn on again and it should have the settings in play
Old Apr 2, 2012 | 04:49 PM
nizzle's Avatar
settings in play?
Also, i cant do the key/reset thing right to even get to the voltage screen
Old Apr 2, 2012 | 04:53 PM
Hulk's Avatar
A Merc
This is how i did it today, turn the key to position 1, hit reset 3 times, then it will show the voltage, then scroll with the up or down arrow until you see dyno, then press + button , then turn it off then back on and you should be in dyno mode, only do this if you are actually doing an actual dyno run
Old Apr 2, 2012 | 04:58 PM
nizzle's Avatar
I did it. I had to change the menu to the outside temp reading 1st.
Old Apr 2, 2012 | 04:59 PM
Hulk's Avatar
A Merc
That's weird I didn't do that..hmmm
Old Apr 2, 2012 | 05:03 PM
nizzle's Avatar
that is weird. Diff year maybe?
Thanx for the help anyway tho
