Images of Defective W211 E55 Gas Tank
PLATINUM SPONSOR
That is nasty! I saw an e55 that was hit in the front end and gas was all over in the back seat. Scarry if you smoke as well.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Symptoms were gas smell and pooling at driver side sender upon filling up. Initially dealer resealed sender, then replaced sender then replaced gas tank which ultimately fixed the issue.
Ok seriously old *** thread revival.
However I wonder....Hulk what gas do you use? Seems ridiculous that after such a change it goes bust in a year
Mostly chevron 93 and always did the chevron fuel system cleaner every 3k miles. It's just a bad design. I remember when the dealership was fixing it the first time and I left and literally 100 miles later fuel smell again and new sender was needed
2005 E55, GMC Whipple Supercharged Quadrasteer Denali Pickup,Big Bored Hyabusa with nitrous
The plastic tanks have bumps at the top where the mounting threads are bonded into the tank. The tanks crack around these bumped areas. Mine started to crack there. The spot I'm talking about is higher than the sending units. So, when you fill all the way up the gas leaks and puddles around the sending unit. This is what happened to mine but the sending units can also fail and cause the same problem. That's why the extended warranty covers the tank as well as the components.
