Need a shorter belt for the smaller supercharger pulley
Old Jun 29, 2012 | 05:18 PM
vipermike's Avatar
Viper SRT-10, CLS 55 AMG, 2012 Tacoma Off Road 4x4
I need a shorter belt for the smaller supercharger pulley, does anyone know what the proper size is? The stock belt is way too long...
Old Jun 29, 2012 | 05:22 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Gates belt part number K080496 and the green heavey duty version K080496HD
Stock belt is 51"
Old Jul 2, 2012 | 05:41 PM
vipermike's Avatar
Stock belt is 51"
Thanks Shardul!
Old Feb 6, 2013 | 09:19 PM
JoeNobody's Avatar
Mercedes
Stock belt is 51"
Either something is up with the belt I bought, or the K080496HD does not fit. In using the smaller pulley, and the belt simply won't fit. It gets close to fitting with the tensioner fully opened, but it won't make it.
Old Feb 6, 2013 | 09:28 PM
OZZYAMG's Avatar
03 W211 E55
Hi
Is a shorter superhcarger belt definetly required when using a smaller supercharger pulley?
Regards,
OZZYAMG
Old Feb 6, 2013 | 09:36 PM
E55Greasemonkey's Avatar
This place is a joke.
I run the smaller SC pulley with the stock MB belt, not sure why you are having a problem.
Old Feb 6, 2013 | 09:51 PM
JoeNobody's Avatar
Mercedes
Smaller belt is not required, as tensioner will pick up the slack. Some have said a slightly smaller belt has better grip (presumably because of more tension from the tensioner), but that might be pure speculation.
Now to order a belt of the correct size :-(
Old Feb 6, 2013 | 10:17 PM
mphox's Avatar
SCCA GTA Chevy Intrepid, E55, Sequoia, F250
I run the smaller pulley with the stock belt as well. Double check to make sure you have a stock belt size and make sure there are no other problems that may be causing the belt to not fit.
Old Feb 6, 2013 | 10:28 PM
berti_00's Avatar
2016 Cls63s AMG
i use the Gates HD green one... however i will be getting rid of it soon to replace with the longer one with the belt wrap..
Old Feb 6, 2013 | 11:08 PM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Stock belt is 51"
I have a K080505HD which is the gates heavy duty listed as 51" Going by part numbers it should be a touch longer (just under an inch?) then the part number you listed.
Isn't the stock belt 51.4 or something a lil over 51?
Old Apr 22, 2013 | 01:18 AM
OZZYAMG's Avatar
03 W211 E55
Stock belt is 51"
Hi
I am using a smaller supercharger pulley made by Shardul. Which belt is best to use as I need to replace mine?
Should I get a green heav duty version or just goto my local Mercedes dealer and buy a standard belt from them?
Regards,
OZZYAMG
Old Apr 22, 2013 | 01:22 AM
AMGPilot's Avatar
2004 E55
FYI if you are using Shardul's belt wrap kit you need a belt 4" longer than the belt you are presently running
Old Apr 22, 2013 | 01:34 AM
OZZYAMG's Avatar
03 W211 E55
Hi
I don't have a belt wrap kit. I am using a smaller supercharger pulley manufactured by Shardul.
Regards,
OZZYAMG
Old Apr 22, 2013 | 02:01 AM
AMGPilot's Avatar
2004 E55
Ozzy, it was a general point of reference, it wasn't referring to you or your post's, there are people in this thread getting ready to install the belt wrap kit and this is info they need
Old Jun 6, 2013 | 11:54 PM
AMG013's Avatar
W211 E55 AMG
Anyone know what belt I need:
Sharduls S/C Pulley
Belt wrap kit
ASP 175mm crank pulley
Thx
Old Jun 7, 2013 | 01:01 AM
BBBSS's Avatar
I wanna edit this but its too late so I'm quoting to update this belt is a touch SHORTER but slips on easily and runs great. I was even able to get it on the stock pulley. It is .4 or .6" shorter if I remember correctly. Matches the smaller supercharger pulley very well.
Old Feb 8, 2015 | 12:00 PM
Afr00t's Avatar
'03 CL55 AMG & '09 SL63 AMG
What size sc pulley do u have?
