for those who have the dreaded valve cover knocking sound...
Old Jul 14, 2012 | 11:05 AM
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
Check your Idler pulleys! For the past month I've had an extremely horrid knocking sound which I swore was coming from under the passenger side valve cover. Now we all know how loud our engines are normally, but this sounded like there was a loose bolt inside the valve cover grinding away. It would go away as the revs went up but on idle the noise was unbearable. Anyways, my Indy shop is usually backed up a week or so so i decided to do some investigatng and found that my s/c idler pulley had a slight wobble to it. Upon removing the belt, the wobble was pretty damn significant. I hopped on eBay, ordered a $3 6203zz bearing, replaced the bearing inside the pulley and what do you know...no more knocking!
Just want to point out as well, there was absolutely no other symptoms besides the noise. The car still pulled like normal and drove the same. Of you're experiencing other issues it may infact be valvetrain issues.
Lastly. Many thanks to pearlpower for the awesome DIY, literally saved me a couple hundred $$$ and a bunch of sleepless nights.
Old Jul 14, 2012 | 01:45 PM
desired_speeds's Avatar
2007 SL55 AMG
can you link me to the bearing you used?
Old Jul 14, 2012 | 02:14 PM
AMG_RL's Avatar
This is the one I used: http://www.ebay.com/itm/130692941606...84.m1497.l2649
Old Jul 14, 2012 | 02:48 PM
2007 SL55 AMG
thanks! and I just need one right?
Old Jul 14, 2012 | 03:13 PM
AMG_RL's Avatar
Yes just one, the serpentine belt pulley's bearing isn't replaceable. Here's the DIY also https://mbworld.org/forums/w211-amg/...ng-repair.html
Old Jul 14, 2012 | 04:03 PM
berti_00's Avatar
2016 Cls63s AMG
or replace the whole set with the ASP set
