W211 E63 Airmatic to KW coilovers converson review
Pros: Handle like a sport cars, adjustability of height, rebound, harshness or softness, no more worry about airmatic failure, money saved on future parts and labor for failed airmatic components and Lifetime warranty on parts.
Cons: Do you really need 18 setting? Rear shocks adjustment access is a PIA, still too stiff at the lowest setting. It’s been a month and 700 miles since I got the coilovers installed. IMO, Coilovers suspension should be for peoples who take their car to the track maybe once a month. For daily driver like me it will have somewhat hard ride due to a stiff suspension even at the lowest setting. Also, my car is lowered but not slammed and I’m having trouble going over large speed bumps and steep driveway without bottoming out and scraping the front lip. If you going to lower your car more than 2” than avoid steep drive way or speed bumps. Also, you going to have rubbing issue with aftermarket wheel if you have 3-4 adults passenger in car now that you no longer have the airmatic to raise your car to it proper height. Honestly I missed the abilities to put my car in “4x4 mode” with a push of a button and the smooth ride. In a conclusion, for those who use their car for daily usage like me going to work, grocery getter or taking your family out to dinner or taken a short trip than it not worth the conversion. Since Arnott’s industries are selling the rebuilt struts for reasonable price with a life time warranty you can replace one or two strut before it time to sell your car. Honesty how often does these airmatic strut goes out under normal usuage? My airmatic have 48K miles and still working good. I don’t plan to keep my car after it hit 85K miles. Anyway, If I could go back I would have not done the conversion. Maybe with more time I might change my mind. Total cost $2850 KW V2 $1750 Parts and labor $1600 Sold airmatic components on Ebay $500 Total weight saved: 33 lb Total airmatic weight: 81 lb KW coilovers: 48 lb Compressor pump: 9.2 lb Front airmatic struts: 39.2 lb Rear airbags: 15.6 lb Rear shock absorbers: 17 lb |
Thank you very much for the review!!! Honestly very helpful for those of us that are/were considering the conversion.
I agree with you. My car is at 139K, still on original airmatic components and considered a switch to coilovers when mine fails, but the fact that the car is a daily driver, the comfort of air ride, and the ability to raise the car for driveways/car full of people/hauling stuff in the car has led me to just replace airmatic components when the time comes.
An additional point to consider is KW's customer support. I ran into several issues with the KW V3s on my Porsche, and the CS was extremely frustrating.
You had to ship the failed product back through the dealer to Germany, where they decided whether to cover you or not. |
Are you sure about the weight? GrantwoodTx said it was 22 pounds saved not 33 lbs. Maybe he weighed it wrong. The more weight savings the better.
Originally Posted by mchapparone
(Post 5285374)
Originally Posted by tbone
(Post 5285396)
Originally Posted by DVC
(Post 5285488)
Originally Posted by e500slr
(Post 5286546)
What kind of rims and what size tires too?
I have an 07 E63, and my airmatic is bugging the crap out of me. I don't want to deal with it anymore. I don't want to go too low, what's the highest you can set it at? |
Originally Posted by infantry
(Post 5286657)
I am thinking that going to coilovers from airmatic would also negatively effect the drag racers on this platform too. The soft cushy suspension really helps in weight transfer, and it would probably be very hard to hookup with the stiff coilovers, so that is another negative right there.
Coilover Conversion
I had a front airmatic strut die last month, fortunately replaced under warranty, but will leave well enough alone based on your review.
Thanks for the excellent write up. |
Very nice Review. Thanks for sharing!
(Post 5286657)
Originally Posted by Peter_02AMG
(Post 5286743)
I'm riding on my stock wheel right now and it still very stiff and bouncy. Bugging you how? You can keep the stock height with coilovers if you want.
Originally Posted by FT-Performance
(Post 5286721)
Taking out 4 pillows of air cushion with 3 dampening settings to replace with some stiff riding coilovers? :crazy: You gotta be kidding me... My back still hurts from driving around in a harsh riding M3 for 3+ years.
Never the less. Still a great review peter 02amg! |
Would be very interesting to compare to a E63 W211 P30. It is quite a bit stiffer than the normal suspension.
Great bit of info here gents! One question after doing some additional research. Does the Coilover Installation Kit make a big difference in the install effort? https://www.ecstuning.com/b-genuine-...2113501806kt1/
