Ultragauge?
Old Jul 20, 2012 | 05:07 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Ultragauge?
Anyone used this ?
Any good ?
Dashdaq is super but not cheap.
http://www.ultra-gauge.com/ultragauge/index.htm
Old Jul 20, 2012 | 05:11 PM
Toadster's Avatar
2005 E55 AMG
dang $70 on sale - that's worth messing with!
Old Jul 20, 2012 | 05:18 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
this guage will only dispaly the PID your vehicle supports. another thing to consider is the more parameter you choose to sample via the OBD2 the slower the sample rate gets.
Old Jul 20, 2012 | 06:27 PM
03'55AMG's Avatar
AMG
If this is worth anything as far as quality go's I will most likely pick one up.. anybody tried this?
Old Jul 20, 2012 | 09:52 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
I'm with Shardul, the sampling out of the OBD2 is the slowest thing on earth!
Old Jul 21, 2012 | 12:16 AM
cij911's Avatar
one car at a time
Sorry guys but I disagree 100%, plus there are not too many options, unless you want to tap into the sensors themselves...
I use Zeitronix and Innovate loggers and both work great (coupled with their respective widebands).
Old Jul 21, 2012 | 12:22 AM
FT-Performance's Avatar
FTP-E55///AMG
We are a Dashdaq Dealer now Pretty Basa$$ unit. defenitly worth checking out:
https://mbworld.org/forums/vendor-an...st-prices.html
Old Jul 21, 2012 | 02:31 AM
PACougar's Avatar
I'm confused, if you use Zeitronix and Innovate to do the logging the sensors ran into those will have a great sampling rate. It's just the OBD2 stuff that samples very slowly.
Old Jul 21, 2012 | 09:15 AM
cij911's Avatar
one car at a time
OBD2 sampling rate is not that bad - perfectly fine for tuning. Anyone that tells you otherwise is mistaken. Could it be faster and is more data better, yes, but is it necessary - 99% the answer is no.
The only sensors that folks typically connect directly to the Innovate and Zeitronix units are wideband O2 (for air fuel ratios), MAP sensors (for boost or vacuum), and EGT (for cylinder temperatures).
Timing, RPM, and LFT/ SFT, and other data are general pulled from the OBD2.
Old Jul 21, 2012 | 02:01 PM
PACougar's Avatar
I don't know about your car, but mine skips 5 or more mph while accelerating and I wouldn't depend on it's timing being very useful while tuning with such large gaps in the data. Of course take all the chances you want.
Old Jul 22, 2012 | 09:43 AM
cij911's Avatar
one car at a time
Something is wrong with your setup or you are logging way too many items via OBD2. You should be seeing ~ 10 data points /second which is more than enough for tuning. I have never logged MPH so it may be a function of the output speed vs.OBD2 speed.
Generally I log AIT, RPM,and timing from OBD2 and AFR from my wideband.
Old Jul 22, 2012 | 11:36 PM
PACougar's Avatar
My RPM also has pretty big jumps to it as well. I can tell the timing is being logged slowly because I can see the gap from letting off of the throttle.
Old Jul 23, 2012 | 01:34 AM
03'55AMG's Avatar
AMG
Guys, Send Steve over at FT Performance a PM about a dashdaq, He'll hook you up!
Old Jul 24, 2012 | 02:41 PM
firstbenzforme's Avatar
Current 2014 Maserati Quattroporte and 2017 GLE 63 AMG retired 2007 E63 AMG
I'll try it...
I gave my old obd2 scanner to my brother and was gonna pick up a new one anyway.. so i'll order this thing and post up some thoughts/faqs after i play with it. Expectations are low but for $70 as long as it functions properly as a replacement scanner i will be cool with it.
