Eurocharged H/E Install Question
I'm installing a E/C heat exchanger and I've got everything positioned where it belongs but now I'm not sure how to best attach the trans cooler to the bottom of the new H/E without damaging it. I remember seeing a couple people talking about how they did theirs, but I can't find them now... Any help or suggestions are appreciated. Thank you!
I drilled out the existing brackets and reused them. I drilled into the HE very carefully, using stainless steel rivets and installed it back in the same place. It makes the bumper bulge alittle, but not bad. A front lip will cover it up completely.
We use Zip ties on each side of the H/E for the Oil cooler to sit below the H/E. I belive the E/C H/E has a threaded nipple on the bottom of it for the cooler for it to thead in. Maybe Jake will chime in. All aftermarket H/Es seem to have a little bulge on the Stock E55 Bumper. Ours, E/C Etc. Unless you have a lip or an E63 conversion will it not be completly non noticable.
Originally Posted by RedBullJnky
(Post 5340544)
+1 for what redbulljnky said, don't use zip ties ur not working on a dodge neon :smash: make the install a Quality one :y
why not mount it behind the H/E?
Thanks for the quick replies and the pics.... I'll try to drill out the old brackets and get it mounted up like RedBullJnky's illustration.
I've done two, and in both cases, just drilled out the lower portion (carefully) and used some very sort sheet metal screws
Yes, very carefully. I used a drill bit stopper on mine. If you go to far that HE is garbage. I did mine in my front driveway and have zero issues. Good luck to you!
(Post 5340633)
I also drilled out my brackets and riveted them to the HE. just be very careful when measuring and drilling.
So I finaly got the install wrapped up and love the look of that BIG h/e peering out through the black grill! I didn't realize that I would have to dremel out the two center mounting brackets on the bumper but it wasn't that big a deal. Got the tranny cooler all riveted in place and although it gives her a bit of a fat lip, I think it's a prety good trade off...
Thanks for the help guys! http://i303.photobucket.com/albums/n...ickem-1/HE.jpg |
is there a good retrofit tranny cooler that could be implemented up higher - say in front of the main radiator?
I have my EC IC sitting on a shelf, gotta get this mod in, Any tips on airing the system out after fitting?
Originally Posted by Alps
(Post 5355455)
Nice! The fat lip is a small price to pay for a nice big H/E :y WELL done!!
