HELP!!! E63 front bumper conversion
Old Oct 3, 2012 | 09:30 PM
fan888's Avatar
2004 E55
Hi guys,
So recently car got into accident, took this opportunity to upgrade my front bumper to E63.
Got body shop order from Gary, then they told me need a bunch of stuff.
My car has parking sensors, so original parking sensors did not fit into the new bumper because the bracket different.
Then fog lights, they said no hardware or nuts and bolt to mount it to the bumper. (are you guys using from the old one?)
Bumper reinforcement, they said need a new one because the old one just sit on top of it.
So bunch of new parts needed to make this thing happen.
Could you guys chime in what you guys did to made this happened.
Thanks a lot.
Car been sit at the body shop for a MONTH NOW!!!!
Old Oct 3, 2012 | 09:43 PM
BenzoBoi's Avatar
Super Moderator
W221
Check this thread. I'm sure your answer is in there somewhere. The whole thread is about adding an E63 bumper so I'm sure you'll find a parts list needed in order to swap out. Maybe it'll help out.
Good luck
https://mbworld.org/forums/w211-amg/...tock-only.html
Old Oct 3, 2012 | 09:44 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
This is what you will need.. As well as the upgraded grill 155 EBAY
From the MB dealer:
211-887-03-27 Pull For Hood Latch $4.25
211-880-09-03 Inner Plastic Support $32.50
211-880-10-03 Inner Plastic Support $32.50
211-880-07-03 Center Inner Plastic Support $20.15
Old Oct 3, 2012 | 09:49 PM
black06c230's Avatar
mgLipGD
Also pop off the sensor brackets on the E63 bumper and replace them with the ones off your E55 bumper. Shop should be able to do it and epoxy them in place much like the stock ones.
Good luck. I have my bumper with sensor sitting in my office waiting on BIP to finish installing tons of goodies!! Pick it up next week, then to the body shop it goes.
Old Oct 3, 2012 | 10:24 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Here is my bill when I got the 63 front end done.. I think this will be every possible part number you could ever need
