Conductor plate.. anything else I should know?
Old 01-29-2013, 09:30 AM
cwmateiuc's Avatar
2006 E55 AMG
About to replace the conductor plate, connector, fluid & filter in my trans.
The car stopped engaging and just revs no matter where the selector is.
Anything else I should change or check while I am in there?
Are all of the speed sensors that go bad built into the new plate?
Old 01-29-2013, 09:36 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
i dont think so swapping the conductor plate will solve you issue. I think there are 3 speed sensors on the plate.
Old 01-29-2013, 09:44 AM
cwmateiuc's Avatar
2006 E55 AMG
Well it's what lead to it doing this that makes me thing that's what it is based on other threads explaining exactly my symptoms... So I'm really hoping it's just that.
The three speed sensors.. are they apart of the plate or are they separate?
Also, would you be able to tell me what you think it could be?
Old 01-29-2013, 10:11 AM
shardul's Avatar
yes they are a part of the conductor plate.
what error codes is star showing?
I also have a conductor plate that is in good working condition. if you want to try that before spending the money on a new plate.
Old 01-29-2013, 10:40 AM
blackbenzz's Avatar
haters crazy
Conductor plate is a common problem on these cars. Good luck, hope it fixes your issue
Old 01-29-2013, 10:50 AM
shardul's Avatar
also check the TCU, transmission fluid wicks up through the harness into it.
Old 01-29-2013, 11:15 AM
cwmateiuc's Avatar
2006 E55 AMG
Yeah I was going to do it in my driveway but I need to get it to a lift as doing it in my driveway isn't really possible lol
When the car is cold it goes into gear.. weird.
Yeah I have a new plate, connector and I'm going to take out the TCU and open it up and possibly clean it.
Old 01-29-2013, 11:58 AM
blackbenzz's Avatar
haters crazy
I believe the newer model E55 s came with the updated connector seal which prevents the Trans fluid from wicking up the wires
Old 01-29-2013, 12:02 PM
shardul's Avatar
so they can still leak.
If i remember correctly the OPs car had some under carriage damage prior to purchase.
Old 01-29-2013, 12:39 PM
cwmateiuc's Avatar
2006 E55 AMG
The issues were intermittent and then got worse, little worse, here and there even more worse, until this.
So I'm hoping it's my ground plate because before all of these issues started arising i bottomed out on a non painted speed bump pretty hard and the issues slowly started popping up the next day
And the transmission fluid did come out somewhere before becuase last time it was slipping adding fluid is what fixed that particular issue.
So I'm planning on changing the plate and plug, removing and thoroughly cleaning the TCU.. then obviously new filter and fluid.
P.S. I read something about springs breaking in half? That's only with really early versions of this transmission, right?
Old 01-29-2013, 12:47 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
I have a brand new conductor plate if you need one. Pm me a offer. I'll even throw in 5 liters of fluid
Old 01-29-2013, 12:56 PM
cwmateiuc's Avatar
2006 E55 AMG
Thank you to you and Shardul
But I already have a conductor plate, plug and about 14 bottles of fluid lol
Old 01-29-2013, 03:29 PM
cwmateiuc's Avatar
2006 E55 AMG
BTW, does my car have these springs? I read somewhere that they are only in the older versions of this transmission...
http://www.benzworld.org/forums/w210...tor-plate.html
Also, is there a drain plug for the converter like in the above post?
Old 01-29-2013, 03:48 PM
shardul's Avatar
from what I have seen the W211 E55 AMG dont have a drain plug on the convertor.
Old 01-29-2013, 04:49 PM
cwmateiuc's Avatar
2006 E55 AMG
you happen to know which if there are any "hidden" bolts to take the valve body off? I can't seem to see them all when I'm laying in my driveway.. lol
Old 01-29-2013, 05:48 PM
shardul's Avatar
none of them are hidden
Old 01-29-2013, 06:22 PM
cwmateiuc's Avatar
2006 E55 AMG
There was one in the middle that I missed..
Got it off..
In the process, laying on the ground at all, got some crap on the bottom of the valve body from touching it and moving around under the car (rock driveway)...
Is brake cleaner safe to use to clean it?
Old 01-29-2013, 07:27 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
There might be a plug in the converter,
It is reccomended not to drain it unless you are removing the transmission or replacing the converter,
Gator
Old 01-29-2013, 09:20 PM
stockC43's Avatar
Got it off..
I've never had any issues with using brake cleaner on it but there are different formulas so just be careful. Whatever you do do not get gravel in the valve body ports. You don't want to turn a $100 conductor plate into a new trans pump, valve body etc..
Old 01-30-2013, 08:12 AM
cwmateiuc's Avatar
2006 E55 AMG
Yeah I cleaned the crap out of it to be sure.
Also, there is a little yellow plastic piece in there.. made the mistake of not looking exactly how it went.. anyone know?
It's a little yellow plastic piece that when the valve body is out of the car you can spin it and remove it also.
Edit.. I found a pic on Benzworld
it's the piece on the bottom of the black plastic on the left. That yellowish thing. I don't know exactly how that goes when actually putting the valve body back on. I just want to make sure so I don't have to do this all over again lol
Old 01-30-2013, 10:13 AM
stockC43's Avatar
That goes on a pin on the internal shift linkage. Should be easy to spot
Old 01-30-2013, 10:16 AM
cwmateiuc's Avatar
2006 E55 AMG
Thank you!
Old 01-30-2013, 12:44 PM
cwmateiuc's Avatar
2006 E55 AMG
Whats the best way to clean them? Compressed air and brake cleaner?
I keep finding a little dirt in places, not sure if it's dirt from the driveway or wear from the discs in the trans.
Old 12-11-2013, 09:41 PM
servicetech's Avatar
2006 E500 4Matic
parts
Do you still have these parts?
Old 12-11-2013, 10:00 PM
stockC43's Avatar
Pm sent
Quick Reply: Conductor plate.. anything else I should know?
