M113K Upper Fixed / Clutchless S/C Pulley
Old Jul 18, 2013 | 04:41 PM
  #176
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Originally Posted by Toadster
true - but the clutchless pulley will always be 'on' - whereas the clutched version will have connect times (sure it's small) but no more S/C chirp either - right?
I'm curious how effective the bypass will be in comparison to the clutch - could be interesting on a high-rpm downshift... could definitely impact the exhaust note depending on the RPMs
i opted to get smalled(77mm) then the small sc pulley with clutch that is on my car now.
i will dyno it to see if there is that much significant gains.
Old Jul 18, 2013 | 05:01 PM
  #177
viren.89's Avatar
2004 E55 AMG
Bro you planning to do before and after dyno ? or you will be using your previous dyno as a base reading ?
Also , just to avoid any mishaps I think you should wait until they properly configure out the tune or did they already do that ?
Old Jul 19, 2013 | 08:18 AM
  #178
Manuyc's Avatar
the tune has not been configured out yet. i still have not sent it to jerry.
i was going to get it properly tuned dyno and then slap pulley on and adjust again tune/dyno
besause i think i can still get more hp the way the mods are as pre clutches pulley.
Old Jul 28, 2013 | 03:27 PM
  #179
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Install vid of fixed SC pulley. Real easy, just slide on, line up two small dow pins with holes in FSCP and then tighten and torque to spec.
http://s991.photobucket.com/user/Vit...09426.mp4.html
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 28, 2013 | 04:16 PM
  #180
Toadster's Avatar
2005 E55 AMG
oh man, I was waiting for a pinch on the hand from the pulley snugging up
Old Jul 28, 2013 | 09:35 PM
  #181
Forrest Gump 9's Avatar
shrimp boat
Do you have a version that will eleminate the magnet too?
Old Jul 28, 2013 | 10:47 PM
  #182
Shifter's Avatar
E55, SL63, ML550
The magnet is behind the rear black drum and is fixed. Wouldn't gain any loss in rotating mass eliminating it. But you could remove it prob if wanted.
Old Jul 29, 2013 | 06:46 AM
  #183
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
The "cover" of the magnet is rotating though. You need a special puller tool according to this thread here, to take it off.
Any more news about the fixed SC pulley is highly recommended.
Does fuel consumption rise on part throttle, because according to that 55K guy, now he has even power at part-throttle...
Old Jul 29, 2013 | 12:20 PM
  #184
Shifter's Avatar
E55, SL63, ML550
What prevents the new pulley from spinning on the shaft? Does it mate up to the drum tight therefore locking them both togeather?
Maybe it's my iPhone but I can't get the vid to work.
Old Jul 29, 2013 | 01:02 PM
  #185
Manuyc's Avatar
looks so easy! Mine is in my trunk but I also have a little wire to be soldered somewhere
Old Jul 29, 2013 | 05:41 PM
  #186
Denroll's Avatar
'06 E55
Edit: was joking about JB Weld. But I ran that stuff on a cracked motorcycle engine case for a year with no problem.
Regarding the magnet "cover" that spins... How much does that weigh?
Old Jul 29, 2013 | 05:59 PM
  #187
blackbenzz's Avatar
haters crazy
Originally Posted by Denroll
In the vid, he puts a few dabs of JB Weld in between the pulley and drum, and then tightens the bolt.
I don't see him do that in the vid Isn't there a torque spec on the SC pulley bolt?
Was Michael Jackson doing the install? lol
Old Jul 29, 2013 | 06:28 PM
  #188
Crissus's Avatar
Hahahaha. JB Weld.... There were really people gluing ball joints with it on YT and wondered why they brake on the round-course
There is some more info on the fixed SC pulleys with pics on PSC Forums, would be nice to see them here as well - thank you :-)
Old Jul 29, 2013 | 06:51 PM
  #189
Denroll's Avatar
'06 E55
No JB Weld, that was a joke for shifter who couldn't see the vid.
I'll bet exotic could torque that pulley using his bare hands. He's a big dude.
Old Jul 29, 2013 | 08:23 PM
  #190
PLATINUM SPONSOR
2003 CL55
FSCP does not mate to magnetic drum. Drum can be removed and will not effect pulley function but would not recommend taking the drum off and running the SC that way.
3 ways the pulley is fixed to the sc shaft; interference fit , 2 factory dow pins and bolt pressure.
__________________
www.ultimatepd.com
Old Jul 29, 2013 | 08:26 PM
  #191
PLATINUM SPONSOR
2003 CL55
Yes, and top of my thread says to torque to spec but if somone can`t read that or has to ask, may be better to let a dealer do your work for you. I can recommend a few good ones.
__________________
www.ultimatepd.com
Old Aug 17, 2013 | 11:44 AM
  #192
Phil_W's Avatar
C32 AMG
Hi guys,
if it works, it would be fine, but if the ecu want to declutch the sc pulley, maybe cause the iat is too high, your pulley can't declutch, the iat's are going to get higher and higher, and i.e. at 300kmh its very hard for the engine... If something is wrong, the ecu cut the boost by disconnect the clutch, with a fix pulley you cant.
No problems if maybe the ic pump is faulty and the iats getting higher?
I ask this cause i made me a fix pulley too for my c32.
Old Aug 17, 2013 | 11:59 AM
  #193
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Let us know when the tune is perfected without any excuses and or hickups and I might be interested at that time. Keep up the efforts.
Old Aug 17, 2013 | 12:00 PM
  #194
Crissus's Avatar
Originally Posted by Phil_W
Hi guys,
Hallo Landsmann :-)
This is my biggest concern too so far. What are the safety mechanisms done by Eurocharged??? No-One is willing to give answer so far it seems.
For my case, i would never ever build any custom Gauges into my classy CL-Class coupe, and would ruin therefor the great interior look of the car. No Way.
So, if EC can do more to the ECUs Data than flipping around with Hex Values for injection and ignition timing/amount, ie. having the bypass flap open fully suddenly if IATs exceed for instance 170°F and once they are lower than 150°F put the flap back into normal operation, then it would be awesome.
If not, well that would be very bad, if no other good method is looked into (ie. cutting timing tremendously on high IATs, whatever)
Old Aug 17, 2013 | 01:12 PM
  #195
Phil_W's Avatar
C32 AMG
lucky guys, m113 sc got at least bypass valves to open them at high iat or other fails, m112 even not
I think in us the problem isnt that big like in germany - when the cars drive there 300kph for a longer time?
Old Sep 7, 2013 | 02:29 AM
  #196
lm7's Avatar
lm7
2003 E55
Any video or dyno numbers of any guys running this pulley successfully?
Old Oct 7, 2013 | 06:06 PM
  #197
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
Any updates
Old Jan 28, 2015 | 12:40 PM
  #198
Afr00t's Avatar
'03 CL55 AMG & '09 SL63 AMG
anybody got clear instructions for installations including what to do with the resistor?
Old Feb 3, 2015 | 07:36 PM
  #199
jesterEOD's Avatar
2004 E55
Resistor location
Can someone please give a description of where this resistor is supposed to go. I have the pulley installed and need to put the resistor in but I am lost.
Old Feb 3, 2015 | 08:09 PM
  #200
PLATINUM SPONSOR
2003 CL55
You loop it into the plug that plugs into the supercharger on passenger side near the SC pulley.
__________________
www.ultimatepd.com
