Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class AMG: How to Replace Brake pads/calipers/rotors
Step by step instructions for do-it-yourself repairs
Common replacement and maintenance parts - all in one thread
#126
2005 E55
as LED technology improves, here's a new design that has 2,000 lumens - great for fog lights (depending on if you're color matching, etc)
these H7s will fit the E63 foglight setup
LED Headlight features:
Plug & play, No need to cut and wires.
Low Power Consumption, Long lasting.
200% brighter than your stock Halogen headlights.
Low Voltage Protection, High precision Constant Current Driver Chip.
Built in IC Circuit (Current Regulator)-Prevents LED Damage From Voltage Variations & Spikes.
Up to 30,000 Hours Service Life.
Specifications:
Power: 50W/set
Voltage: DC12V-24V
Material: Aluminum
Color temperature: 5000K
Beam Angle: 360 degree
Size: Approx 19.6mm in diameter and 93.2 mm in height
Input: 2.2A ± 0.1A
Lumens: High beam1800lm/bulb
LED quantity: 2PCS Cree-1512 chips each
Certifications: CE, RoHS
Package included:
2 - Cree LED bulbs
2 - Micro-fans
2 - Ballasts
New Brights LED Headlight Conversion Kit - All Bulb Sizes - 50W 3600LM Cree LED - Replaces Halogen & HID Bulbs - H7 $99
E55 bulb size (9006)
50W CREE LED Head Light Head lamp KIT H4 H7 H8 H9 H119005 9006 Color 5000K $95
Specifications:
Power: 50W/set
Voltage: DC12V-24V
Material: Aluminum
Input: 2.2A ± 0.1A
Package included:
2 - Cree LED bulbs
2 - Micro-fans
2 - Ballasts
#127
surely someone brave enough on this forum has tried em! the old style LEDs weren't good at all, but these new CREE style are supposed to be pretty insane!
#128
IGNITION SYSTEM
98-2010 Mercedes Benz Spark Plug Ignition Wire Set Of 16PCS $114 shipped
1 step colder NGK (2309) LFR7AIX Spark Plug - Pack of 4 $33.80/4
OEM 4 New NGK Iridium IX Spark Plugs LFR6AIX-11 # 6619 $30/4
New 4 Button Remote Key Case Shell for Mercedes-Benz $9
IC088 0001587803 UF359 98-07 MERCEDES Ignition Coil Set 8PCS + Spark Plug Set 16PCS E55 $263 (yes coils AND plugs)
Bosch 00107 Ignition Coil $60
The stock OEM spark plugs from Mercedes are LFR6AIX-11, correct?? I don't want any '1 step colder' plugs or any of that. OEM only.
#129
at 130k it's probably a good time to swap it out - did mine around 80k, the response is quicker (maybe it's a placebo)
http://www.lifetimeledlights.com/H7-...hts-_p_64.html
Haven't had time to install either yet, probably this weekend.
I like the fact that the lifetime lights have reflectors around the diode. They are getting good reviews around the net as well. We'll see.
Look for an update from me after I attempt the install.
#132
I got a set that you linked from Amazon. However, while reading up on LED headlights, I came across this setup from lifetimeledlights.com, which I bought as well.
#133
I plan to do a full write up on these soon with comparison pics to my e320. Overall, my review of these are positive.
However, I believe that our projector lenses are hindering throw.
The color is excellent. The brightness is excellent. The cutoff is good. The throw is OK at best.
Give me some time to put it together. I've got a lot of household projects going on now.
#134
yup you got it
NGK (6619) LFR6AIX-11 Spark Plug - Pack of 4
NGK 3588 ILFR6A Iridium/Platinum Spark Plug [factory plugs]
http://www.ngk.com/product.aspx?zpid=9806
While they will fit, the plugs you are referencing in your purchase list are NOT the factory plugs:
NGK 6619 LFR6AIX-11 Single Iridium Spark Plug
http://www.ngk.com/product.aspx?zpid=9871
The difference between the 2 plugs:
- ILFR6A (factory plug; iridium center electrode, platinum ground electrode; 0.032" gap; long life--around 80-100k miles)
- LFR6AIX-11 (iridium center electrode, nickel ground electrode--these will last maybe 24-30k miles; 0.044" gap)
You might want to correct this on your list. Great parts list overall--keep up the work!
#136
I changed my 2006 E55 plugs a couple of weeks ago, and the M-B stamped NGK plugs are the following:
#137
Gents,
I bought this battery:
Aux Battery ACDelco ATX14BS (14-BS) Maintenance Free Absorbed Glass Mat (AGM) Powersport Battery $67
I received it and it says you have to
1. Add the acid
2. Wait one hour
3. Charge it for another 10 hours (refer to instructions)
I dont have a charger, and this stupid a$$ battery didn't come with instructions. Anyone know what to do here?????????????
Many thanks.
1. Add the acid
2. Wait one hour
Many thanks.
#138
I just wanted to add that the Wix 46799 air filter does not fit in the air box of my 2004 E55. The filter is approximately one quarter of an inch deeper than the factory air filter and will not let the box seal properly.
#139
Gents,
1. Add the acid
2. Wait one hour
Many thanks.
1. Add the acid
2. Wait one hour
Many thanks.
What's a fun way to dispose of the acid?
#140
CAREFUL with these batteries that you have fill.. i did mine just as it said to do and couple of weeks later i had airmatic red death light come up... NO idea why after spending money on pumps and all kinds of none sense stuff turns out the battery had leaked acid right on the friken airmatic line and melted it what was a cheap fix costed me alot more... i ended up selling the used pump back etc and got most my money back but just careful when filling these.
#141
Gents,
1. Add the acid
2. Wait one hour
Many thanks.
1. Add the acid
2. Wait one hour
Many thanks.
installed the battery and drove like normal - had zero issues with it.
#142
anyone know the size of the AMG stickers for the caliper? I have a friend who is going to cut me a set
#144
'06 E55
Has anyone tried this yet? Seeing as how the Bosch coil packs are $58 a piece right now, these are quite a bit cheaper. The seller is the same vendor that is selling the engine and transmission mounts for $100/set. I don't need coils yet, but since I'm going to change plugs soon, might as well do coils and wires while I'm in there.
#147
Here's the link for just the 8 coil packs without the plugs. $148 + $14.50 shipping.
http://www.amazon.com/0001587803-MER...=AYZ062M1ZWK81
98-07 MERCEDES Ignition Coil Set 8PCS E55 $134 shipped
#148
added a section
Want to go racing?
HJC CL-16 Helmet SNELL/DOT < $80 shipped DOT/SNELL approved!
- anyone want to add more bits for racing?
Want to go racing?
#150
glad to help!
also, added new plug wires that several have said are a nice update
Magnecor 85240 8.5mm KV85 CN Series Ignition Cable 1997-2011 $172
