What Spark plugs should I run
2020 AMG C63s
I have a 2008 E63 AMG, what spark plugs should I run in my car? I heard about NGK but don't know which ones to go with and what size to gap them with.
Thanks,
Eric
Thanks,
Eric
2020 AMG C63s
07 E63 + 07 CLK63CAB
Serge is the man, he probably just changed his, 6043 NGK iridium think 43 thou is the gap but double check. No need to go with colder plugs. Use a small amount of never- seize on the threads. Only remove the old plugs when the engine is completely cold to avoid thread damage.
Regarding your question, a simple search would help you find :
http://www.ngksparkplugs.com/part_fi...engineid=31806
The REAL SERGE is sergs99m3
w205 C63s, w212 E63,w219CLS500-SOLD! w211 E63, 2006 E60 M5 (KABOOM!)
I put NGK ILZKAR7A10 plugs in my 2008 E63 about 600 miles ago. Gap was set when I got them. (.8mm) Worked like a champ. Simple to install. (Torque spec for the plugs is 22Nm) I agree with the above post about making sure the engine is cold.
I am not Serge @ Benzworks but also Serge : ) ( serge718 - I am in NY / SI ). I did my plugs NGK (6043) ILZKAR7A10 last week. Got them on Ebay. I bought my 2007 E63 with 98K few months ago and have been changing parts on it like a monkey in the zoo with unlimited banana supply . Will post full list of everything done in few weeks.
Serge718
I knew you were into the plugs recently, lol
Did you look into the old pcv valve to see what the issue was?
Must have been a knuckle duster to change!
Like a good German buddy of mine said, sometimes you just have to drive the car and not maintain it constantly, spoken in a thick German accent.
2020 AMG C63s
Thanks guys for all the great feed back. I ordered the NGK (6043) ILZKAR7A10 today (special order). I should have them Friday then off to the dyno with eurocharged software
Thanks,
Eric
Thanks,
Eric
2020 AMG C63s
Hey guys went with the set of NGK (6043) ILZKAR7A10. Car runs stronger now and I cleaned the K&N filters too. Just waiting for the software then to the dyno. I will shoot a before and after dyno vid.
Thanks for all the help
Eric,
Eric,
EGray, hopefully you put a little anti-seize on the threads of the new plugs. The old ones must have made a squeak noise coming from them when removing. Amazing from MB to spend so much time and effort when building an engine to just throw a set of plugs into it. Dissimilar metals love this oversight, to anyone who has ever pulled the threads out of an aluminum head or broke a plug off they will remember the sick feeling they had.
Ps, like the manifold colour change, good thinking.
CAUTION NEWB QUESTION:
So this is way too easy of a DIY to pay the dealer $650(that was the quote i just got).. my only question is how do i set the correct gap?
If you want to close the spark plug gap, gently tap the node on a hard surface. If you want to open the gap, gently pry it open with your spark plug gapper.
My Jeep takes 2 plugs per cylinder, so dual spark plugs per cylinder is not a hoax.
However, this thread states that the E63 only takes 8 plugs
https://mbworld.org/forums/w211-amg/...g-upgrade.html
