Need help from Guys in the Tampa Florida Area
I know I don't have a E55 but I do have a CL with a Superchaged Engine and the CL forums are pretty much dead. Im driving the car down from NYC and will be in the Tampa area in a few hours (Currently in Jacksonville) I have been getting a Check Engine light for the past couple of hundred miles (luckily I have a bull**** scanner) I have been getting codes for Injector #2 and #5 pretty much every few hours so I would reset it and keep on driving but at one point last night in Georgia the Check Engine Flashed a few times then went on I felt the car loosing power so as I got off the Freeway the car started shaking pretty bad I re scanned it again and along the Injector codes I also had a few codes for Random Missfires on Cylinder 3 6 and 7 I erased it and kept driving so it was somewhat normal and around 9 pm last night decided to get a Hotel in Jacksonville. This morning the when the Check Engine came on it showed only one current code for Injector #5 I erased it now it still shakes slightly on idle but when driving the car feel fins. I have a few more hours to go to Tampa and was wondering if there is a good specialist for the 113 Engines that could take a look at this. Any help is greatly appreciated
Thanks Guys
P.S. I installed the 550 cc Injectors from Eurocharged 2 weeks ago so maybe a failty injector might be my probles
Thanks Guys
Triple check all the connectors.
This sound like what happened to me. Same codes for injectors and misfires. Turned out to be a few loose connectors.
E55 greasemonkey and Sir Boost Alot would be the guys in that area to talk to.
Good luck!
Good luck!
Give Andrew or Eric at Lutz Performance a call 813-949-3540. They're on Dale Mabry/Hillsborough, they work on my C55 (N/A M113) and know their way around the MB even though they specialize in BMW. I personally would stay away from MB Tampa and St. Pete, if you feel the need to take it to a dealer drive to Clearwater.
Thanks guys at first i tought i had bad gas but after a few bottles or fuel injection cleaner and octane booster the problpem still remains now it seems to be showing even inje tor number 1 i guess its hard for ke to believe that i have 3 bad injectors i will try to check the connections tommorow just not sure if i should have the car on or off when doing this
Well i just did cylinder 2 and 5 since those we the codes i wiggled them around and unpluged them and plugdem them back in and i stikk had the same.issue but now the scanner is showing injector #4 and a missfire cylinder #4 WTF is this car possesed or maybe i have an issue with the tune?
Thankz guys at this point im ready to rent a car and drop the car off to a benz mechanic im staying in Rus5kin anyone know a good benz.guy in the area? Thanks
