I think my supercharger is f&$ked
2004 E55 AMG
Last night on my way home the old girl died right as I was pulling her into the driveway. It starts right up but as soon as you would give it any gas (enough to engage the blower) it would stall out. I noticed it smelled like clutch....only one clutch on this car. I tried a few more back up/pull up sessions to confirm and low and behold the old sc pulley was smoking.
Now the optimist in me is thinking "your car has 117k" on the clock. I'm sure you just need a new pulley / clutch." We'll this morning I go out again and this time I have someone drive it with the hood open so I can see what's going on. Now I can see the pulley clutch is engaging but as soon as it does it locks up....not good. I'm an optimist but I'm having a hard time thinking this is anything other than my supercharger being fubar'd.
So has anyone rebuilt one of these blowers?
Are they hard to find used?
And how the hell do you get the stock pulley off? Are people using breaker bars?
Thanks guys...
Thanks guys...
2004 E55 AMG
Are you sure it's the pulley only? I would think if the pulley was bad it would just spin against the clutch and not engage the blower. To me the fact that it's seizing leads me to believe that the clutch is engaging but the blower screws won't turn. I hope you are right as that is MUCH cheaper.
2004 E55 AMG
2004 E55 AMG
Since it takes 30 seconds to pull the belt off I gave it a shot. The car drives much better, no more stalling. But it's obviously going nowhere if I give it any substantial gas due or no boost.
So what does this tell you? Again thanks for helping.
2004 E55 AMG
The supercharger will not turn by hand from what I can see. I would think I should be able to move it by grabbing the black pulley but she's not budging. This would explain the clutch smoking and the pulley locking up when trying to engage.
MERC
That does not sound good, I know I just had my SC fluid changed and it was very low, I beleive they got out only about 30ml. My car is an 03 with 78K miles on it. Sounds like a great time to consider a whipple!!
might have something lodged in the blades of the supercharger :-/
07 E63 + 07 CLK63CAB
Was there any rattling or grinding noise previous to the clutch smoking, If so possible bearing seized in the front of the supercharger. Try to place a belt wrench on the supercharger inner pulley face and try to turn the supercharger in the reverse of normal rotation as to free the stuck charger. Or just remove the clutch and look at the bearing behind it.
Sound like you have a few possible scenarios:
-Something got "inhaled" and jammed the rotor blades
-One of the bearings seized up or came apart jamming or colliding the blades together
I doubt there is much left to rebuild, your clutch is cooked by this point, if the rotor blades or the case is damaged you need a new blower. If it is strictly a bearing issue and no internal damage was done, you can try sourcing the new bearings through NTN.
The bearings will have an NTN part number. Last time I checked it will not register on their site under part number search. I spoke with their engineering dept a couple years back and they said that the part number I supplied was an OEM specific bearing and was not available separately. However you should be able to have one matched by specs(OD/ID, Thickness, type, etc)
2004 E55 AMG
Thanks guys, I'm sort of stuck until Monday. That's the soonest I can have the time, space and equipment to rip this thing apart. I will report my findings.
Grip grip thank you, if you can sit tight for 48 hours I would appreciate it.
2004 E55 AMG
Blower is definitely seized. Grip Grip was nice enough to ship me a good used unit today so I should have it here by Wednesday. When I get it in IM going to swap it over and take apart the seized one to see what happened. I dont really have the luxury of down time so a swap is the fastest way for me to get out of this. If the blower is salvageable I will just have a spare or I can talk AMS into making a whipple conversion using the CAD data from the old unit lol.
I am using this as an opportunity to change my injector O-rings, Valve cover gaskets, powder coat my plenums and just do a general gasket overhaul up top. Just trying to find the silver lining here lol.
Stay tuned for possible SC carnage pics :/
Good you can get replacement, but by chance have you worked on the intake system lately, IE changed filters or removed anything associated with the induction? Have you checked or changed the oil in the SC case ?
2004 E55 AMG
I have never checked or changed the oil in the SC, I have read its not needed to change it but then just recently I have read on here that its certainly a good idea to do so.
The intake system has not been touched in probably 8 months. I put new filters in back then.
PLATINUM SPONSOR
glad you find a good used unit.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
